Transmission Fuel
Yes you can. I will tell you the process of how to do it.
  • At first, you need to remove the transmission fluid from the oil pan completely before filling the transmission fluid.
  • To do that, You need to elevate the car so that you can go under it. You will see the transmission fluid pan which will be screwed with 6 to 8 bolts.
  • To empty the fluid from the pan, you may notice a drain plug on the pan. Unscrew the drain plug, and the used fluid will come out.
  • Incase, you dont see a drain plug you need to unscrew the oil pan completely and remove the fluid.
  • After removing the fluid from the oil pan, elevate you car bac to the normal position.
  • Now to put the transmission fluid inside the car, you need to remove the transmission dipstick and add the fluid as per recommended by your daler or mentioned in the car manual. To refill the fluid you may need a funnel to do so.
  • Manke sure, that you don't overfill the fluid. the amount of fluid that came out should be more than the amount of fluid to refilled again.
  • After doing this, start your car and let it come to the normal temperature.
Thats it! its done.
  • 4 weeks later...
