Transmission slipping?
  • 2 weeks later...
Transmission slipping is a serious problem actually. When the gear doesnt operate properly. Whenever you have difficulty in putting reverse, or changing your gears to top it means the transmission is slipping. Sometimes when you hear the grinding noise when trying to change the gear, it indicates transmission slipping.
