engine oil
ahmedk
Checking engine oil level is very simple. When you do that, make sure the engine of the car is not hot. Open the hood of your car and check for the dipstick in the engine. Remove the dipstick and clean it nicely so that there is no oil on it. After cleaning it, dip it again and tale it out. You will realize the level of oil on the stick. Mostly the dipstick comes up with signs like min. /max. Or cross signs or L/H (low and high) which indicates at what level you need to put more oil in the engine.
