Proportioning Valve
amid
How to replace the proportioning valve in hybrid?
To replace the proportioning valve, park yur car on the level ground. You need to raise the front platform of your car. Do it unsing the jak and make sure to lock the jack so thatthere is not accident because of the slip of the jack.
After ajusting the jack and the stand, locate the propotioning valve under the car. During the replacement of your valve, you can clean the surface also as you may not do it on regular basis.
Check if there is any leak from the proportioning valve.Remove the wiring harness and push the valve from the car and disconnect it. You also have to unscrew all the bolts from the valve.
Take your new valve, and connect it the same way to disconnected the old valve. But make sure, the new valve is as per specified in the manual of your car. Connect the harness back and screw the bolts.
To ensure if the valve is working fine, bleeding the brakes will help.
