Problems in the Fuel System
Fuel System is like a heart to the car engine. The fuel system basically delivers the fuel in the complete car system to function. The fuel system is crucial and that’s why need proper attention. Sometimes rash driving also causes issues with the fuel system. I know some common problems that one faces in the car because of the fuel system.
  1. Engine Sputtering: When engine suddenly starts sputtering at high speed that is because of issue in the fuel pump. Fatigue fuel pump is the cause of it. When there is loss of pressure in the fuel pump, the engine starts to sputter.
  2. Lost power when accelerating: Fuel pump needs to maintain an amount of pressure to deliver the fuel when accelerating the car. Sometimes the fuel pump is unable to do that. When it regains the pressure, it speeds up with acceleration.
  3. Engine surging: This is also very common when the fuel system doesn’t work properly.
  4. Engine doesn’t start: When the fuel pump is completely malfunctioned, the fuel does not reach the engine to start it.
In all these problems, the fuel system either needs to be fixed properly or need to be replaced depends on the level of malfunction. But yes, ignoring the fuel system issues is foolishness. So if you think you are facing any of these troubles, then may be your fuel system needs attention. Sometimes just understanding what fuel pump does avoid lot of problems. To avoid any severe issue with the fuel pump, it’s always recommended to give your car for regular servicing. In regular servicing, the fuel pump is properly scanned and diagnosed for any issue persisting or any near future possibility to get any issue. That’s why we say; handle your car with care. It’s a machine not magic!
  • 8 months later...
