Peugeot General Discussion Forum | Peugeot 208 Forum | Peugeot 301 Forum | Peugeot 308 Forum | Peugeot 508 Forum | Peugeot 607 Forum | Peugeot RCZ Forum | Peugeot 2008, 3008, 5008 Forum
You need either a voltmeter or a multimeter which is capable of reading volts. Most multimeters that you can buy in a shop will be able to do it. Simply set the range on it to anything above 12 volts, connect the red probe to the positive battery terminal and the black probe to the negative battery terminal. Even if you connect the probes the wrong way round, it doesn't matter. You will still get the same reading, it will just have a minus sign in front of it.
