How to take good care
  • 4 weeks later...
Well this is really an interesting topic to discuss on. Just buying a car is not it, you actually need to take a good care of your car. It’s really important to know what your car needs at what time. Now to take good care of your car, remember few things:
Number one: Servicing of your car. Make sure you give your car for regular servicing. It always helps in maintenance of the car as it avoids any severe issue in the car for long run.
Just have a look: Whenever you are going to sit in the car, always scan your car from outside. Check the tires, headlights and everything.
Maintain all fluids: From the motor oil to the brake fluid, always maintain the proper level of all the fluids in the car.
Battery: Let’s say you are going on a vacation and you are not gonna use your car for more than 10 days. In that case, remove the car battery and keep it aside. That helps in better battery life.
If you face any trouble code or any light on the dash, always consult a workshop before it’s too late. Not only those, if you feel misbalancing or vibrations in your car, never ignore such issue and take your car to the service center before the issue becomes really big and may be you will pay a huge money for the replacement of any car part.
And try to go easy on the transmission of your car. Sometimes when you are driving really speedy or jerking speed, it affects the transmission badly. And the replacement of the same is really expensive. So take care of that as well.
