harishah Posted November 18, 2014 Report Share Posted November 18, 2014 What if I don’t change the transmission fluid regularly? Link to comment Share on other sites More sharing options...
salman Posted December 10, 2014 Report Share Posted December 10, 2014 Doesn't matters which ever car you drive: be it manual or automatic, transmission fluid plays a significant role in maintaining the transmission and running the engine smoothly. If in case you do not maintain the level of transmission fluid or do not change the transmission fluid regulalry, the gear box is badly affected by it. It spoils the smoothness of the engine and the transmission becomes too hard that its difficult to change the gear from one to another. It also makes grinding noise in the car. Link to comment Share on other sites More sharing options...
harishah Posted December 12, 2014 Author Report Share Posted December 12, 2014 I see! I will definitely make sure that I change the transmission fluid regularly. Link to comment Share on other sites More sharing options...
tenace Posted April 7, 2015 Report Share Posted April 7, 2015 My car repairer accidentally flushed away all of the transmission fluid. Two days later I was on the road when i couldn't properly change gears. The stick couldn't enter the appropriate gear. After a while, it was impossible to drive. The repair was really costly, but it was covered by the repairer. So, check and change this fluid regularly. Link to comment Share on other sites More sharing options...
