pressure in petrol tank when pumping
mahaa
after getting my car serviced the car seemed fine till now when I fill in the petrol it creates an over pressure situation in the gas tank.The pump stops after about .3 gallons and when I take it out you can here all of the pressure hissing out.
what is it
Cant understand your problem corectly.
Every car fuel tank has pressure build up to push the fuel to the engine thru fuel pump. If petrol cap is opened and heard some hissing its pretty normal. Leave it open for a minute and then refill if you think its not taking more fuel. Lets the car be running when u open the fuel cap in petrol station, so that pressure can be remove faster.
