transmission oil
Check the transmission have any dipstick in engine bay or not (usually some car has that). If not then go to eppco lube guy and they can check the gear oil level and condition for you. Checking with dipstick is easy just like checking the engine oil level. If not mechanic or some one need to go under the car and open the level bolt of transmission to check the level and condition. Hope it helps mate.
  • 2 months later...
  • 1 month later...
