Wrangler heating while towing
Baraz
31 minutes ago, Javier M said:
I would look into changing the thermostat from the stock to one with lower temperature like a 180F thermostat this will open at lower temperatures than the stock thermostat.
If that doesn't help then you need to consider a radiator upgrade.
Besides the thermostat you can also invest in a good aux fan to keep things cooler.
