2010 Pajero Tiptronic Gear Shifting Problem
15 hours ago, Barry said:
Fit a kill switch on the power line to the valve block. Job done 😬
...or get a Pajero with a manual gearbox.
I once removed the valve body socket on a Camry only reverse and last gear worked didn't matter if on l or 2 or d it would only run on last gear there was no pick in car....
I'm still not sure if @Barry was serious or not when he suggested that the OP should cut the power to the valve body to prevent untimely gear shifts. I'm sort of hoping he was just joking...
