Traction control
Hi guys... i have a 3.5 pajero.. i pulled the cable of the air sensor while engine is running.. then i saw the check engine warning on the dash.. what i did was remove the negative cable of the battery to reset.. after putting it back the engine check warning was gone but the traction off warning light up now its stuck on the dash hope somebody can help thanks...
I assume you mean the air valve for the 4wd system? Why did you pull the cable off?
Check the fuses. Switch into low range, drive a couple of hundred meters, go back into high and drive another couple of hundred meters. If it doesn't switch off it'll need reset. I have the tool to do it.
Disconnecting the battery without a very good reason is NEVER a good idea, so you were lucky this time.
