Toyota General Discussion Forum | Toyota 86 Forum | Toyota Aurion Forum | Toyota Avalon Forum | Toyota Avanza Forum | Toyota Camry Forum | Toyota Corolla Forum | Toyota FJ Cruiser Forum | Toyota Fortuner Forum | Toyota Innova Forum | Toyota Land Cruiser Prado Forum | Toyota Land Cruiser Forum | Toyota Previa Forum | Toyota Rav4 Forum | Toyota Sequoia Forum | Toyota Tundra Forum | Toyota Yaris Forum | Toyota Zelas Forum
Hello gearheads(I hope it's not inappropriate),
So, I feel like the land cruiser 100 has a traction control built in, and the only time you can switch it off is while messing with the off road gear. Help me out here.
If there is one how do I turn it off or get something built (like a button) to turn it off?
Also, one more thing that lead me to believe this is that it is impossible to get your wheels to spin (burnout) by just putting your car into D. You have to switch it to L4 (offroad gear) to get the rear wheels to hustle.
If you want to do proper burnouts, man up, buy a manual and consider fitting a linelock/brake bias valve.
If you want to disable the TCS, try pulling the ABS fuse.
But ABS and TCS is completely different.
I don't wanna do burnouts I wanna know about the TCS
You can do burnouts in sand in D, but not very prominently on road.
Almost same year as yours I had 2003 model in 2006-08, doing some burnouts while learning off-roading in boat
dayumn :D did you lock the axles? also locking the axles would make the wheel spin right, but would it harm the diff?
Nope, it was just in D. In LC being heavier and underpower, if you notice I took 5-6 meter run before steering, that's the only key it works every time and later with more control you will master that correct momentum to steer at right moment.
TCS works on the same system system as ABS. It uses the same wheel speed sensors and cuts the power and transfers to another wheel when appropriate.
Yep both use all the same sensors and even the actuators but for different situations...
