shadow79 Posted April 26, 2018 Report Share Posted April 26, 2018 as some of you have seen it at the workshop i had taken a work of converting a sc300 2jzge to a 1jzgte turbo from a toyota soarer work turned out to be longer then expected because of some customer intervention but in the end has almost been complete here is the video of it fired up VID-20180426-WA0016.mp4 2 Link to comment Share on other sites More sharing options...
Gaurav Posted April 26, 2018 Report Share Posted April 26, 2018 Sounds pretty sweet, well done. So finally who win the owner or you? In changing all rubbers and seals before plonking the engine? 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
shadow79 Posted April 26, 2018 Author Report Share Posted April 26, 2018 (edited) whatever he brought we fixed the valve cover seals, main seal, ck pulley seal, cam seals, timing belt, aluminium cam sprockets,converter seals and output shaft seal but some parts he was going to get custom built but couldn't get them (turbo piping) so i convinced him to fix what we have at hand and use the car while those parts last and while the car is in use he can put things according to his taste and later upgrade it...its better have a running car then one stopped in workshop waiting for parts... Edited April 26, 2018 by shadow79 more info Link to comment Share on other sites More sharing options...
Barry Posted April 27, 2018 Report Share Posted April 27, 2018 We did this conversion before but it was 2JZ with 50 shot Nas 1 3 Link to comment Share on other sites More sharing options...
Gaurav Posted April 28, 2018 Report Share Posted April 28, 2018 On 26/04/2018 at 8:55 PM, shadow79 said: whatever he brought we fixed the valve cover seals, main seal, ck pulley seal, cam seals, timing belt, aluminium cam sprockets,converter seals and output shaft seal but some parts he was going to get custom built but couldn't get them (turbo piping) so i convinced him to fix what we have at hand and use the car while those parts last and while the car is in use he can put things according to his taste and later upgrade it...its better have a running car then one stopped in workshop waiting for parts... A smart owner, finally he managed to do what he really want to do than just listening. 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
shadow79 Posted April 28, 2018 Author Report Share Posted April 28, 2018 (edited) 4 hours ago, Gaurav said: A smart owner, finally he managed to do what he really want to do than just listening. its not about smart or not its about waiting for parts which is a roll of dice if it fits or not (he ordered a blowby valve which took 15 days to reach and in the end was not for his car)he also ordered a big ass radiator which was so big and had brackets different than the ones which was in both cars so it means that the radiator was also for a different car Edited April 28, 2018 by shadow79 more info Link to comment Share on other sites More sharing options...
Gaurav Posted April 28, 2018 Report Share Posted April 28, 2018 I meant smart owner to replace as many parts, seals and rubber component of a scrap engine as oppose to your advice to plonk it as it is. 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
shadow79 Posted April 28, 2018 Author Report Share Posted April 28, 2018 that engine was a running one we started that half cut before buying it...and the important things like the seals and timing belt must be changed as its been a sitting thing for who know how long but about things like the turbo pipes and other switches which are original and working but are being changed for no apparent reason... Link to comment Share on other sites More sharing options...
shadow79 Posted April 28, 2018 Author Report Share Posted April 28, 2018 @Barry can you teach that 50 nas trick and what parts it needs... 1 Link to comment Share on other sites More sharing options...
