GIC Posted June 13, 2018 Report Share Posted June 13, 2018 Hello all, Looking for a reliable bmw garage to fix the crankshaft issue. Difficulty in startting the car - in the Morning. Link to comment Share on other sites More sharing options...
Barry Posted June 13, 2018 Report Share Posted June 13, 2018 How do you know there’s a problem with the crankshaft? 1 Link to comment Share on other sites More sharing options...
GIC Posted June 13, 2018 Author Report Share Posted June 13, 2018 Hi, had it checked on the computer in a garage.Later he even changed it.Bought an aftermarket part for 180/-. Just worked for 1 day, Next morning again the car wont start. Quote . Link to comment Share on other sites More sharing options...
treks Posted June 13, 2018 Report Share Posted June 13, 2018 (edited) Crankshafts generally do not cause cars not to start. Going by the price of the part you mention, I'd say that they replaced the crankshaft sensor, which is the thingamajig that creates the ignition spark. If so, the problem was clearly not related to the crankshaft sensor, and you should find a proper mechanic next time. Edited June 13, 2018 by treks Link to comment Share on other sites More sharing options...
desertdude Posted June 13, 2018 Report Share Posted June 13, 2018 Damn should have bought a BMW if I knew the parts were that cheap, entire crankshaft for just 180dhs Link to comment Share on other sites More sharing options...
treks Posted June 13, 2018 Report Share Posted June 13, 2018 4 hours ago, desertdude said: Damn should have bought a BMW if I knew the parts were that cheap, entire crankshaft for just 180dhs ...and you even get the fitment for free Link to comment Share on other sites More sharing options...
shadow79 Posted June 13, 2018 Report Share Posted June 13, 2018 seems it also could be the wiring to the ecu if you have changed to a known working sensor... if you can show what was the initial computer diagnosis that would also help to the right direction... 1 Link to comment Share on other sites More sharing options...
