shadow79 Posted August 2, 2018 Report Share Posted August 2, 2018 when you have rust on chassis or body usually the body shops just clean and put putin and face it and paint it only to make the paint pop back up and the rust sprouts back and the other way is to chop up the area affected and put a new sheet or chassis piece and hammer it back in place then face it and paint it common with some models of prado as its a/c drain drops water on right chassis and makes hole in it and the mitsubishis where the body almost always gets rusty have seen a fancy way to deal with it hope someone else doesn't do this.... this image is sourced from the internet and guess such things happen more in snowy areas where they salt the roads 1 Link to comment Share on other sites More sharing options...
Barry Posted August 2, 2018 Report Share Posted August 2, 2018 As someone from a country where they use salt on the roads, I’ve seen my fair share of rusted out chassis’s. That’s the first time I saw one held together with jubilee clips though. The only answer is to cut the bad bits out, treat it with tannic acid, box it up and fill it with wax. 2 Link to comment Share on other sites More sharing options...
