Luism Posted August 30, 2018 Report Share Posted August 30, 2018 Hi all I have 2006 cayenne S and every now and then since like a month ago I get the flash up on dash with ( Four wheel drive system faulty) then goes off for a few days and comes back on. The shifter does work and the trans can be put in low and high range and goes perfectly well but its a nuisance getting the light pop up every now and then. Anyone know why this happens please? thanks all Link to comment Share on other sites More sharing options...
Gaurav Posted August 30, 2018 Report Share Posted August 30, 2018 Get your battery checked and changed (if needed), I had this same issue but only once and next day battery died. So this four wheel drive faulty is a known issue when battery dying as it has electronic oil and when that oil gets a fluctuation in voltage it throws this error. Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Luism Posted August 30, 2018 Author Report Share Posted August 30, 2018 I have had the battery changed and same issue comes up Link to comment Share on other sites More sharing options...
sidhan Posted August 30, 2018 Report Share Posted August 30, 2018 1 hour ago, Luism said: I have had the battery changed and same issue comes up Have you got the correct AMP battery, as I had similar 4WD light in Mercedes on weak battery and if the battery is wrong AMP especially lesser AMP then also you might get this warning light Link to comment Share on other sites More sharing options...
Luism Posted August 30, 2018 Author Report Share Posted August 30, 2018 Thanks Sidhan I will check but should be the correct battery as I changed it in a Porsche shop Link to comment Share on other sites More sharing options...
Barry Posted August 30, 2018 Report Share Posted August 30, 2018 Send me a message. I’ll stick it on the computer some evening after work and see if I can pull some fault codes for you. Link to comment Share on other sites More sharing options...
Luism Posted August 30, 2018 Author Report Share Posted August 30, 2018 Thanks Barry. If you give me your number will give you s bell after weekend Link to comment Share on other sites More sharing options...
Barry Posted August 30, 2018 Report Share Posted August 30, 2018 DM sent Link to comment Share on other sites More sharing options...
