Yes it’s possible to sleep inside. And also you can very easily take the back seats offand use them outside the car. It’s a powerful and very reliable car, very capable off-roader, but not the most comfortable.
You can have a look at this previous discussion on Carnity
https://carnity.com/topic/13309-any-tips-on-buying-a-used-xterra?tab=comments#comment-46886
  • Thanks 1
Welcome to Carnity and thanks for asking an educated question than just - I need a car.
All your reference and background give me enough idea to make a perfect recommendation, but before I get on to that I like to get few tricky things clear based on my experience of owning and driving offroad for over a decade.
  • 7 seater and a capable offroader can't go together in one sentence. For offroad - car power to weight ratio is king (google this to understand what I am saying). Higher the power to weight ratio you will enjoy that 4x4 more for offroad.
  • Focus on buying a daily commuter + capable 4x4 than putting the Africa road trip into an equation to limit your option. You can (or should) always rent 4x4 for such special requirement than pushing your daily driver way too far, as it's just a one-off expedition you are planning (If I'm not wrong).
  • For offroad category, sand and mountain are TWO DIFFERENT WORLD. Excellent mountain climber can be a waste in sand and vice versa, so here you need to decide which is most needed and if you need both then you will limit your choices for handful 4x4.
Prado's are much better than Land Cruiser as it's tad lighter and less in size. LC is a boat and good for everything except hardcore dune bashing, if you limit to beach sand and newbie level drives you are fine with LC. Converting LC gearbox are way too out of the league to even talk about.
Nissan Patrol falls in the same category of LC - heavy and reasonably good for everything except hard-core dune bashing unless you do some crazy mods and then get in trouble with RTA.
Land Rover LR3, LR4, Discovery can be awesome for daily commute + mountain + beach sand but not for dune bashing.
Jeep Wrangler has it all, but too small for sleeping, even unlimited one too.
Xterra and FJ Cruiser are the only actual all-rounder 4x4 that you can do mountain + Sand + hardcore dune bashing + daily commute + sleep in a car.
Pajero's are third best due to their limited approach and departure angle if you go this route only buy 3.8 liter and get the rear bumper metal plate to kill the sand scoop (will explain if you go this route). Once you get to the hard-core dune bashing, you can look into lifting it a two inch for better ground clearance.
Now here is the tricky part, you choose what you want:
  • Prado will give you much comfy ride for daily commute and also do whatever you want but in a long run slightly more expensive to maintain considering regular offroading.
  • Xterra and FJC little less comfortable for the daily commute, but less maintenance in the long run with regular offroading as they are made for such use in first place.
  • Toyota (Prado and FJC) will hold better resale value than Nissan Xterra.
  • Xterra already discontinued and you may get spare parts for another 5-10 years or google how long Nissan committed to supporting Xterra parts.
  • FJC is smallest of all suggested to not to best fit sleeping in car criteria. Xterra is slightly bigger than FJC and Prado is the biggest among these 3 choices.
Best is to view a few cars and see how rear seats fold, to visualize if you can comfortably fit along with your offroad gears. How nice and comfortable it drives, as every person has a different definition of comfy.
Hope you got enough food for thought, good luck.
  • Like 3
  • Thanks 1
  • Haha 1
Fj I get it but Prado of which era are you suggesting..? Fj and Prado from 04 onwards and Lc after 07 share the same engine gear...? V6 1gr and they too are strong cars but lc100 has this curde ready for all vibe to it...parts availability side of all the cars you have mentioned more votes should go to Lc 100
Edited by shadow79
more info
Sleeping inside the car has some pros and cons imho. During colder winter seasons it keeps you warm, but you need proper ventilation and that means keeping some windows open. If you don't have mosquito nets you will be attacked the whole night by those little buggers. On the other hand during warmer months the lack of real ventilation will make your car too hot to sleep in.
I completely understand that it's a safety choice for you. You can maybe compromise on that part with a few things:
* Bring a dog with you (if you have one or maybe one from a friend). It will be a perfect companion on all your trips and dogs will alert you if something is wrong (wild animals, strangers, etc..)
* Get yourself a tazer or some tear gas. If you're planning to do Africa it might come in handy.
Looking at your budget of 40k i would consider a Pajero (i know i am biased :) ). They are reliable, not too expensive, and made for the stuff you mentioned. That budget will get you one with some miles on the clock but as there are so many available on the market that have just been used as school dropoff SUV it should be very easy to find a decent one with acceptable milage. Agree with @Gaurav on the 3.8 if you have the option of choosing.
Welcome to Carnity !
  • Thanks 1
Thank you all so much for your advice, it has been invaluable.
I'm considering the Prado, however what option should I consider in terms of year, model etc? V6 4l LTR? It's a minefield out there haha
Also would you recommend that I buy direct from the owner or via a dealer? I'm wary of both options to be honest.
Don't take a Prado into Africa- I have extensive experience of African overland expeditions, and I have never seen Prado's (or SUV's in general) do well there. Best thing to do is follow Gaurav's advice; if you want to do Africa, rent a vehicle from a reputable operator.
11 minutes ago, desertdude said:
Yes and that doesn't help.
Aren’t we all at some point ? After all, our opinions are based on experiences and mistakes we made in the past... The FACT is that a Pajero is a viable option here.
And by your own words its not, a single woman on her own should get a dog and some tazers and teargas just so she can get a Pajero! 😂 😂
  • Haha 2
Strange. I know many, ok a few who have taken their SUVs for long African overland trips without issues they would have faced if they had taken any car. And how does one expect to do a overland trip in a sedan anyways? Btw the post says road trip not overland, but by seeing how bad road conditions in many African countries is a sedan even for a road trip doesn't sound too suitable.
I've nothing but SUVs or Trucks do over landing trips in Africa, or anywhere else for that matter
Only issue I can even think of is it being a petrol instead of Diesel.
Love to hear why SUVs arn't a good choice for an overlanding vehicle for Africa
  • Similar Content
    • By Frederic
      When joining Carnity Off-road Club, there will come a time that you’ll need to start looking for deflators, pressure gauges, compressors, flag, etc...
      Dragon Mart is a wonderful shopping paradise but finding the item you need is indeed sometimes a daunting task. So I listed below some shops and their locations that might be of help:
      Off-road Flag
      Section: EA
      Address: EA01
      Shop: S&D Autoparts
      Deflator tool and pressure gauge
      Section: EB
      Address: EBD05
      Shop: Taizhou Yian Trade
      Two Way Radio
      Lots of options, but the BA section has the most shops. Look out for the big CRONY labeled shop. They have the
      Motorola MT777 = 120 - 150 AED. Crony MT777 = 80 - 120 AED Also the Baofeng UV-5R is still popular and easy to find. Costs about 75 AED.
      Floor Jack & Tools
      JZX shop in section EA, no. EAA25
      2 Ton floor jack with swivel neck = 120 - 150 AED (Recommended) Tool kit = 50-100 AED
      Compressor
      Mainly available in BA section. Have a walk and haggle a bit. The Camel logo brand is pretty good. Available in single or twin cylinder model.
      Single cylinder = 100 -150 AED Twin Cylinder = 150 -200 AED (Recommended)
      Please take note that we are not affiliated with these shops nor do we give any guarantees about their items.
      We solely provide the location where you can find these most common items to save your time.
    • By Xaf
      Is it maybe an idea to share important docs in the Off-road whatsapp group?
      Like;
      -Frequencies
      -How to guides
      -Emergency numbers (UAE rescue, Police, Hospitals)
      I think this will be an added value, docs are instant accessible, instead of going to the forum and search the correct topic.
      When posting a new drive, you can make the members aware that they can find the documents with the applicable info in the WhatsApp group.
      Food for thought.
    • By Frederic
      As i have now visited Oman for the second year in a row, i wanted to start this topic with describing the wadis and places i visited, and my experiences. There are lots of other wadis and things to see and do, but i will just mention the ones i visited and give a brief explanation on what they are about. Once you google the specific areas you will find hundreds of photos and more information.
      https://www.omantripper.com/
      Above mentioned  site has really nice information on the topic.
      The best season to visit Oman is between Mid-October to March as the temperatures become enjoyable.
      Visting the Musandam protectorate is also nice and I will post a topic on this one later.
      Trip to Oman preparation
      * Arrange your visas online in advance. https://evisa.rop.gov.om/. Visa on arrival is not allowed anymore from what i've heard.
      * Make sure your car insurance has Oman coverage. If not ,you will need to purchase one at the border itself (bit of a hassle).
      * Do not carry alcohol  or other items which you would not be able to travel into UAE/Oman. Drones are not allowed.
      * Make sure the car is registered under your name and that the driver is part of the travel group.
      * If driving in convoy, a two way radio is very handy to stay in touch and announce the coffee breaks.
      * Make sure your car is in proper technical condition. Pass by your mechanic to have all fluids checked before leaving. Check your tyre pressure, and verify if the spare wheel is OK.
      * Top up the fuel regularly to avoid running empty. There are nowadays more and more petrol stations, but some remote areas will require a long drive to find one.
      Wadi preparation
      Visiting a wadi is a fantastic thing to do with family and friends, but you have to come prepared if you want to experience it fully. You will need the following:
      Cap or hat to protect you from the sun as well as sunscreen Food, snacks and plenty of drinking water. Swimming clothes and towel.. Sturdy footwear with good grips: something that can get wet and you may need to swim with  (old sneakers or water shoes from Decathlon will do). Life jackets for the children. Camera and water proof bag: In many places you will need to swim in the pools to go from one place to another. We used the Decathlon waterproof special zip lock bag that you can put around your neck, that holds your phone and car keys. Other items that can get wet can be put in a rucksack. It is recommended to arrive in the early morning (7-8am). The more touristical wadis can get very busy after 10am. Dress respectfully: bikinis and cleavage are not really well accepted.  When you enter a wadi and see the
      first water pool, do not think that this is the end of your destination. A wadi is a stream that can sometimes be kilometres long and involve hiking or driving till the end. Ask around and the locals will gladly show you the sweet spots. Camping preparation
      If you're planning on camping, be aware of the following:
      * You can freely camp on the beaches, but many of them have pebbles, so take an air mattress.
      * Be careful when roaming around the bushes at night. There are snakes and scorpions around. Long pants and closed shoes are recommended. I had a very very close encounter with a viper recently.
      * Do not camp in the wadis. There is risk of flooding and you will never make it out in time once a storm hits you.
      * Do not camp near river beds or stagnant water: mosquitos will be having the time of their lives devouring you or attacking you.
      These are the places we visited on our 2018 and 2019 trip:
      Wadi Shab
      Wadi Shab parking area:  22.839733, 59.247116
      You can easily park underneath the bridge, and a small boat will carry you across the river where the adventure starts. You can choose between following the walking path, or using the wadi pools to swim from one side to the other. The reward is at the very end where you can swim in a cave.
      This is a perfect wadi to start with. Its family friendly, not too crazy adventurous, and you can decide for yourself how far you want to go.
      You do not need a 4x4.
      Wadi Tiwi and Mibam Village
      My personal favorite wadi that makes you truly feel you are in another world. You will need a 4x4 to navigate through the very steep and narrow village road. You will be greeted by the local youth that will offer to give you a hand carrying your bags, assist your children, and show you the most beautiful places. We had 3 local boys that really helped us out and were the perfect guides.
      Once you reach the village, you have to descend along the terraces where you will see banana trees, mango trees, and many others. The biggest reward is at the bottom where you can swim in a huge caved area with lush greeneries and waterfalls. Reaching the bottom is not possible with children. Its a tricky descend and climb where the locals will give you a hand, but in theory this is the kind of thing where you would need some climbing gear and safety ropes. Picture below shows idiot me doing without climbing gear but with help from a guide.
      Starting point:  22.822144, 59.258530
      Bimma Sinkhole
      23.036267, 59.071988
      This is a sinkhole near the coast, and nearby Wadi Tiwi and Wadi Shab. It's a small circular lake with turquoise waters, approx. 20m deep. If you stick your feet in the water, the little fishies will give you a free foot scrub
      There is a play park next to it, so the kids can enjoy while you have some snacks.
      Wadi Al Arbeieen
      Starting Point: 23.078278, 59.045630
      This wadi involves a very nice winding road, where you will need a 4x4 to venture through the water passings and river beds. They are not very deep so a regular SUV or 4x4 will manage.
      It's about a 20mins drive to the actual parking. The wadi is consisting out of nice water pools where you can take a dip, or you can go for a walk around the area.
      Wadi Bani Khalid
      This wadi is very popular among the tourists, so it is recommended to arrive early. It has many beautiful water pools, and the more adventurous people can go a bit further into a bat cave (Muqil Cave).
      Other things to see and do in Oman:
      Muscat:
      Capital of Oman. Visit the souqs or some of the historical buildings or just stay overnight to catch up on some sleep. The beach is also nice.
      Nizwa:
      was originally part of the trip, but we left it out because of lack of time. Apparently it is an old historical town, nice to to for a stroll or eat at the local restaurants.
      Sur:
      As we visited the Ras Al Jinz Turtle reserve, we stayed into a nearby hotel in Sur. The Sur Plaza Hotel was a welcoming place and the comfort of a real bed and shower is a bliss after the camping activities.
      Sur is a calm town with some nice forts and watch towers.
      Ras Al Jinz Turtle Reserve:
      Ras al Jinz Turtle Reserve محمية راس الجنز
      Ras al Jinz، Sur, Oman
      +968 9655 0606
      https://goo.gl/maps/asetNTxmVGeDE9FH8
      Definitely worth a visit to see the turtles hatching in the sand and going back into the ocean. Beautiful building with hotel and facilities. Nice restaurant with buffet. We went for the evening visit that started at 8:30pm.
      The most beautiful thing I saw that night was the night sky. The moon was not out and it was pitch black in that area.
      Reply with your feedback, questions, or information! Let’s share the best spots for this winter season !
    • By Jeh
      What's the Cost of Buying a New Car vs Used Car?
      Does this rule apply for UAE cars as well? ]
      If not which points to be considered when it comes to GCC cars.
    • By syedyaseer
      @GauravSir i have found in couple of places in your above post, you have mentioned you need to have proper 4X4 and not SUV. Could you please elaborate more on that. Till date i thought or believed that their is no difference between SUV & 4x4. Advance apologies for asking such a basic question here. Just curious to upgrade my knowledge and educate myself on this particular topic.
      Disclaimer: Im not challenging or testing any of the member on their knowledge/skills. In fact i assume myself as uneducated/fresher on such topics.
