Hi again,
Okay so I'm now actively looking at buying a Prado.
I have seen this one for sale on dubizzle https://dubai.dubizzle.com/motors/used-cars/toyota/prado/2018/12/8/toyota-prado-2008-v6-40-ltr-vx-limited-edi-2/?back=L3NlYXJjaC8%2Fa2V5d29yZHM9dG95b3RhK3ByYWRvJmlzX2Jhc2ljX3NlYXJjaF93aWRnZXQ9MSZpc19zZWFyY2g9MQ%3D%3D&pos=1
I know I can't go by an advert alone and will def go and view it etc... but this one looks decent to me. What should I be looking for to ensure it is "clean"?
Honestly, looks fine, something I would be interested to go have a look if I was in the market for a Prado myself.
Take a flashlight and have a through look in the engine bay and under the entire car for any oil leaks.
Check the transmission fluid. Should be somewhat pinkish and not smell burnt and brown. Engine oil should be at correct level.
Check all the electronics. See if all windows go up and down. Side view mirrors works ac blows cold and ac fan works at all speeds.
Car should drive smooth and transmission should shift smooth through all gears, no clunks and thuds no vibrations. Try to get up to highway speeds and see of it still drives smooth no excessive wind noise, no vibrations and rattles.
Shift it into low range and see it actually engages. Think these are fulltime 4x4 so lock the center diff, button with four wheels with a X in the center and if you can find a patch of sand to test. Go full lock circles slowly on tarmac and wheels should squeal and bind indicating its working.
Oh yeah check engine oil levels should be between minimum and maximum, ask them before you check the oil when was it last changed. If it was recently and its on the lower side or low, means car is burning excessive oil.
  • Like 5
I'll write it all down and make sure I follow it step by step! :D
I really appreciate your help, guys! Can't thank you enough
If you find a car and need a mechanic to inspect it, send me a message
  • Like 3
Follow Desertdude advise as it is, but just be gentle with 4x4 LO gear on the tarmac and don't drive above 30-40 speed, same for turning - be gentle.
You should also check the following things:
  • Ask for full or partial service history and verify its stamped on the booklet or owner has receipts or service details
  • Look for driver side door sill, for oil change sticker when and where it was last changed to tell you a careful owner
  • Skip few speed bumps at slightly high speed (oops sorry) to see how suspensions are keeping up
  • Look closely under the seats and boot carpet for sand presence to verify if the car has been offroad
  • Pull the driver side seatbelt full out and see if it roll back smoothly or need a bit of assist. Slight assist with this age vehicle is acceptable, but if it needs to much pushback then car either has been in an accident or driven very rough on the road or on offroad for sure.
  • When the car is off, open the engine oil cap and put a flashlight inside and it should have a crisp golden color on moving parts and not dark brown - sludge feel means engine oil has been delayed in past or using some cheap engine oil.
  • If the exhaust is dripping few droplets of water, then that means the engine is happy and well kept, use it as a good sign
I definitely will! Thank you for offering. The one that was advertised today is already gone... I'll have to keep looking all the time and be faster next time, but I'm patient enough :)
1
Told you, Toyota especially Prado is a piece of gold with an insane resale value.
Good luck and good if you are patient enough to find a clean deal. It always takes me a 1-3 month to buy a car and sell within a week.
You were right, indeed! Thank you. Let the obsession begin haha
  • Haha 2
while inspecting your prado please make sure that you check the right side front chassis for corrosion as almost all the prados have this problem as the water from the evaporator drain usually drops on that place and corrodes it you really dont wanna have a car with rusty or chassis repaired on the passing paper will put a dent on resale value and when you get it please extend that drain pipe in such a way that the drops end up on the ground....
  • Similar Content
    • By Frederic
      When joining Carnity Off-road Club, there will come a time that you’ll need to start looking for deflators, pressure gauges, compressors, flag, etc...
      Dragon Mart is a wonderful shopping paradise but finding the item you need is indeed sometimes a daunting task. So I listed below some shops and their locations that might be of help:
      Off-road Flag
      Section: EA
      Address: EA01
      Shop: S&D Autoparts
      Deflator tool and pressure gauge
      Section: EB
      Address: EBD05
      Shop: Taizhou Yian Trade
      Two Way Radio
      Lots of options, but the BA section has the most shops. Look out for the big CRONY labeled shop. They have the
      Motorola MT777 = 120 - 150 AED. Crony MT777 = 80 - 120 AED Also the Baofeng UV-5R is still popular and easy to find. Costs about 75 AED.
      Floor Jack & Tools
      JZX shop in section EA, no. EAA25
      2 Ton floor jack with swivel neck = 120 - 150 AED (Recommended) Tool kit = 50-100 AED
      Compressor
      Mainly available in BA section. Have a walk and haggle a bit. The Camel logo brand is pretty good. Available in single or twin cylinder model.
      Single cylinder = 100 -150 AED Twin Cylinder = 150 -200 AED (Recommended)
      Please take note that we are not affiliated with these shops nor do we give any guarantees about their items.
      We solely provide the location where you can find these most common items to save your time.
    • By Xaf
      Is it maybe an idea to share important docs in the Off-road whatsapp group?
      Like;
      -Frequencies
      -How to guides
      -Emergency numbers (UAE rescue, Police, Hospitals)
      I think this will be an added value, docs are instant accessible, instead of going to the forum and search the correct topic.
      When posting a new drive, you can make the members aware that they can find the documents with the applicable info in the WhatsApp group.
      Food for thought.
    • By Frederic
      As i have now visited Oman for the second year in a row, i wanted to start this topic with describing the wadis and places i visited, and my experiences. There are lots of other wadis and things to see and do, but i will just mention the ones i visited and give a brief explanation on what they are about. Once you google the specific areas you will find hundreds of photos and more information.
      https://www.omantripper.com/
      Above mentioned  site has really nice information on the topic.
      The best season to visit Oman is between Mid-October to March as the temperatures become enjoyable.
      Visting the Musandam protectorate is also nice and I will post a topic on this one later.
      Trip to Oman preparation
      * Arrange your visas online in advance. https://evisa.rop.gov.om/. Visa on arrival is not allowed anymore from what i've heard.
      * Make sure your car insurance has Oman coverage. If not ,you will need to purchase one at the border itself (bit of a hassle).
      * Do not carry alcohol  or other items which you would not be able to travel into UAE/Oman. Drones are not allowed.
      * Make sure the car is registered under your name and that the driver is part of the travel group.
      * If driving in convoy, a two way radio is very handy to stay in touch and announce the coffee breaks.
      * Make sure your car is in proper technical condition. Pass by your mechanic to have all fluids checked before leaving. Check your tyre pressure, and verify if the spare wheel is OK.
      * Top up the fuel regularly to avoid running empty. There are nowadays more and more petrol stations, but some remote areas will require a long drive to find one.
      Wadi preparation
      Visiting a wadi is a fantastic thing to do with family and friends, but you have to come prepared if you want to experience it fully. You will need the following:
      Cap or hat to protect you from the sun as well as sunscreen Food, snacks and plenty of drinking water. Swimming clothes and towel.. Sturdy footwear with good grips: something that can get wet and you may need to swim with  (old sneakers or water shoes from Decathlon will do). Life jackets for the children. Camera and water proof bag: In many places you will need to swim in the pools to go from one place to another. We used the Decathlon waterproof special zip lock bag that you can put around your neck, that holds your phone and car keys. Other items that can get wet can be put in a rucksack. It is recommended to arrive in the early morning (7-8am). The more touristical wadis can get very busy after 10am. Dress respectfully: bikinis and cleavage are not really well accepted.  When you enter a wadi and see the
      first water pool, do not think that this is the end of your destination. A wadi is a stream that can sometimes be kilometres long and involve hiking or driving till the end. Ask around and the locals will gladly show you the sweet spots. Camping preparation
      If you're planning on camping, be aware of the following:
      * You can freely camp on the beaches, but many of them have pebbles, so take an air mattress.
      * Be careful when roaming around the bushes at night. There are snakes and scorpions around. Long pants and closed shoes are recommended. I had a very very close encounter with a viper recently.
      * Do not camp in the wadis. There is risk of flooding and you will never make it out in time once a storm hits you.
      * Do not camp near river beds or stagnant water: mosquitos will be having the time of their lives devouring you or attacking you.
      These are the places we visited on our 2018 and 2019 trip:
      Wadi Shab
      Wadi Shab parking area:  22.839733, 59.247116
      You can easily park underneath the bridge, and a small boat will carry you across the river where the adventure starts. You can choose between following the walking path, or using the wadi pools to swim from one side to the other. The reward is at the very end where you can swim in a cave.
      This is a perfect wadi to start with. Its family friendly, not too crazy adventurous, and you can decide for yourself how far you want to go.
      You do not need a 4x4.
      Wadi Tiwi and Mibam Village
      My personal favorite wadi that makes you truly feel you are in another world. You will need a 4x4 to navigate through the very steep and narrow village road. You will be greeted by the local youth that will offer to give you a hand carrying your bags, assist your children, and show you the most beautiful places. We had 3 local boys that really helped us out and were the perfect guides.
      Once you reach the village, you have to descend along the terraces where you will see banana trees, mango trees, and many others. The biggest reward is at the bottom where you can swim in a huge caved area with lush greeneries and waterfalls. Reaching the bottom is not possible with children. Its a tricky descend and climb where the locals will give you a hand, but in theory this is the kind of thing where you would need some climbing gear and safety ropes. Picture below shows idiot me doing without climbing gear but with help from a guide.
      Starting point:  22.822144, 59.258530
      Bimma Sinkhole
      23.036267, 59.071988
      This is a sinkhole near the coast, and nearby Wadi Tiwi and Wadi Shab. It's a small circular lake with turquoise waters, approx. 20m deep. If you stick your feet in the water, the little fishies will give you a free foot scrub
      There is a play park next to it, so the kids can enjoy while you have some snacks.
      Wadi Al Arbeieen
      Starting Point: 23.078278, 59.045630
      This wadi involves a very nice winding road, where you will need a 4x4 to venture through the water passings and river beds. They are not very deep so a regular SUV or 4x4 will manage.
      It's about a 20mins drive to the actual parking. The wadi is consisting out of nice water pools where you can take a dip, or you can go for a walk around the area.
      Wadi Bani Khalid
      This wadi is very popular among the tourists, so it is recommended to arrive early. It has many beautiful water pools, and the more adventurous people can go a bit further into a bat cave (Muqil Cave).
      Other things to see and do in Oman:
      Muscat:
      Capital of Oman. Visit the souqs or some of the historical buildings or just stay overnight to catch up on some sleep. The beach is also nice.
      Nizwa:
      was originally part of the trip, but we left it out because of lack of time. Apparently it is an old historical town, nice to to for a stroll or eat at the local restaurants.
      Sur:
      As we visited the Ras Al Jinz Turtle reserve, we stayed into a nearby hotel in Sur. The Sur Plaza Hotel was a welcoming place and the comfort of a real bed and shower is a bliss after the camping activities.
      Sur is a calm town with some nice forts and watch towers.
      Ras Al Jinz Turtle Reserve:
      Ras al Jinz Turtle Reserve محمية راس الجنز
      Ras al Jinz، Sur, Oman
      +968 9655 0606
      https://goo.gl/maps/asetNTxmVGeDE9FH8
      Definitely worth a visit to see the turtles hatching in the sand and going back into the ocean. Beautiful building with hotel and facilities. Nice restaurant with buffet. We went for the evening visit that started at 8:30pm.
      The most beautiful thing I saw that night was the night sky. The moon was not out and it was pitch black in that area.
      Reply with your feedback, questions, or information! Let’s share the best spots for this winter season !
    • By Jeh
      What's the Cost of Buying a New Car vs Used Car?
      Does this rule apply for UAE cars as well? ]
      If not which points to be considered when it comes to GCC cars.
    • By syedyaseer
      @GauravSir i have found in couple of places in your above post, you have mentioned you need to have proper 4X4 and not SUV. Could you please elaborate more on that. Till date i thought or believed that their is no difference between SUV & 4x4. Advance apologies for asking such a basic question here. Just curious to upgrade my knowledge and educate myself on this particular topic.
      Disclaimer: Im not challenging or testing any of the member on their knowledge/skills. In fact i assume myself as uneducated/fresher on such topics.
