Land Rover General Discussion Forum | Land Rover Defender Forum | Land Rover LR4/LR3 Forum | Land Rover Discovery Sport Forum | Range Rover Evoque Forum | Range Rover Forum
22 hours ago, desertdude said:
Bigger question is why are going to the dealer for service for an out of warranty car in the first place? Hit a jackpot recently we don't know about?
It's not about the Jackpot, it's about continuing the dealer service history for which I paid a fat premium.
However, looks like time to move out now and get actual 120K service at a quarter the price.
Oils tend to absorb moisture which it can react with and change some properties of oil like viscosity or even make it acidic that can affect metals.
It is better to replace regularly. It does not cost much if you love your car.
If Oil properties are know, a regular Oil analysis can reveal if you really need to replace Oil.
My honest advice. It’s a nice car @Gaurav and no disrespect intended.
I’ve never bought into the whole service history thing, I buy on condition and I’ve got a lot of fantastic cars and saved a lot of money doing it.
Sure, you sell it again for less, but you already paid less for it so it all balances out.
I understand that it’s a Range Rover and we all know can be as fickle as a 40 dhs crack addicted diera hooker and hold you to ransom or just plain rob you for fun.
Once you get into the FRRSH trap, it’s difficult to get out of. It’s hard to go elsewhere to get work done because you’re scared of losing your investment.
But, time V Kms is a real thing.
Look at it this way. If you got an awesome deal on a 20 year old Corolla with only 20k on the clocks, the first thing you’re going to do is change the oil and filter along with the timing belt. The timing belt doesn’t need changed for another 40k but it’s a 20 year old piece of rubber and could snap at any time. Smaller financial scale but same problem.
Same with oil. The heat here is intense. Oil breaks down a lot faster than colder countries. I would rather change it for a few dirhams than run the risk of problems down the line.
Warranty issues don’t come into it anymore, as per a thread I posted a few days ago, the UAE government made it legal to service your car anywhere as long as you stick to the manufacturer recommended service schedule and your warranty will still be valid. But investing in FRRSH is a slippery slope and I’m sad to see you caught in it.
If you’re going to keep the car for a while, get it done on the cheap. I’ll even do the work for you myself if you buy the parts. If you’re going to stick to the dealer, work out all the parts and labour costs and add them into the final resale value and see if it’s actually worth it. FRRSH might make the car easier to sell again, but it doesn’t necessarily mean you’ll get your money back at resale time.
OK, Guys, I think this whole thread turning into the big misunderstanding that I'm after cutting corners on oil, which is not true. I'm a kind of guy who gets 10k oil and replaces at 8-9k in all my cars. For offroad even faster at 5-6k due to extreme use.
As per Range Rover manual, it says engine oil change every 12k interval and I am getting at 10k.
This thread was not about engine oil at all. It was about the differential and transfer box oil which is almost doubling the cost (not few dirhams) at the dealership and advised to change at 68K km instead of 120K just because it's completed five years. This almost half mileage change request is bothering me.
Going back to the original question, if everyone thinks here that diff and transfer oil also have an expiry for 5 years, then I'll get it changed.
@shadow79 this Range so far not driven offroad and not started leaking yet as per their leaking DNA.
@Barry I know dealership service history is scam sometimes, but even bigger scams I have seen when you just trust the people words of "regularly serviced" and it has been done just engine oil and filter changed at Enoc for last 10 years. I don't mind paying an extra premium if I get dealer service history to rule out that. And the second reason for this Range was really genuine low kms unlike 200+ kms driven I have seen at half the price.
Change it, it's expensive I know around 120dhs per liter. And you'll need around 4liters for all four. It's cheap insurance. Oil is cheap, diffs, xcases, engines, transmissions are not.
It's old, heat, oxidization, metal filings have probably broken it down and contaminated it by now. And if you don't drive it often or long enough regularly you probably have moisture build up too.
But don't do it just to keep the service history.
  • Thanks 1
I think someone pointed it out. If the oil is in the original packing, it can stay for even 10 years and it won't have an expiry date. It chemically can't..as simple as that.
However in your engine, transfer case and gear box you do tend to have moisture ingress plus some other foreign elements. These can accelerate the degradation of the additives only, and not the oil. That's the reason why there is a possibility of a so called expiry date on the used oil.
  • Thanks 1
You can just open up fill plugs and put a finger in to check the level and also the viscosity I am doubtful that it's bad unless bashed hard off road or reversed kms or parked up to the doors in water for a good time....
  • Thanks 1
  • Similar Content
    • By Atif
      What is your view about the quality of engine oils being sold by ADNOC when compared with other international brands. I am going away from agency service for the regular servicing of my vehicle so wanted to know if semi-synthetic oil offered at ADNOC is safe to use for my Prado.
    • By Gaurav
      After yesterday's drive while coming out to tarmac, I experienced little intermittent blinking of engine oil and realized that its time to top up. After coming out I topped up the engine oil to MAX level which was earlier close to MIN level but in safe zone. Then after topping up still engine oil light was blinking on highway, so pulled over and Jalil checked if oil is coming to lifters from engine oil cap and it was all fine. After one day cool off, just started the car and now its no longer blinking but more of a constant light in D and no light in reverse.
      Any idea what is happening and how we can fix this.....?
    • By Michael sammy
      I need an advise guys, i changed my car engine oil yesterday its a pajero 3.8 lwb 2010 model.
      At the time the mechanic done with refilling the new oil hr show me the new level and it was above the maximum mark with 1 cm i told him you put more than required he said no once you drive the car the extra oil will go in the engine oil filter.
      Honestly i didn't believe that however i decided to go home and check again the next day morning when the car run the oil into the engine and the filter as per his comment.
      However today morning i checked the oil level and it's still the same 1 cm above the maximum mark.
      So the question is that harmful?
      Should I drain the extra oil? If yes how to do that DIY ?
      Ps: I only drove 30km since oil changed.
      Appreciate your advise guys.
    • By powertech auto services
      Powertech Auto Services are the Best Premium Auto Workshop provides quality car care in Dubai. We’re a team of professionals and highly trained technicians who are passionate about everything that has to do with cars! Our management has over 20 years of experience in the automotive maintenance and repair industry in Los Angeles California
      General maintenance and repair services
      Powertech Auto services provide General maintenance and repair services for all major car brands, we are fully equipped Auto service centre that can perform basic as well as complex car repairs. Our workers are all trained technicians and have vast knowledge and experience in car repair for all major brands. We provide all types of mechanical & electrical services for your vehicle
      Car Scanning and Diagnosis
      At Powertech Auto services, we use the latest car diagnostic tools and accessories to widely scan your car performance, strength, and burdens. Our expert technicians perform a detailed car scanning and diagnosis check up and submit the report to you in a short time period. By these inspections help you to understand your car overall performance.
      Powertech Car AC services
      Powertech Provides Exceptional AC Services to its Esteemed Customers. The Air Condition is one of the key parts that need to be functional in countries where there is extreme heat, especially in UAE.
      Our Services are recognized from Los Angeles to Dubai. We provide quality AC services so customers can feel Cool in Quality and Class.
      Pre-purchase inspection or Used car inspection:
      Call our Service Adviser: 0543057156
      Comprehensive Inspection Report Manual Physical Inspection Computerized Report Fair & Transparent Report Detailed Interior and Exterior Check up General performance, noise, fluid condition check up
