Mitsubishi Pajero head gasket is gone
5 minutes ago, Barry said:
It would be worth checking out the clutch too and changing it if it’s worn. Easier and cheaper to do when the engine is already out rather than pay someone to remove the gearbox to do it later on.
Exactly....told the same thing to the mechanic last night 😀
Good luck for option 2 (best choice) and hope she gets well soon with all new organs.
Is this in half cut you sourced, meaning you had a look at odometer reading or was it out of the car?
  • Thanks (+1) 2
Good question, I’ll check with the mechanic.
  • 3 weeks later...
How is the progress going, keep us posted?
I almost forgot this whole thread and discussion in 3 week's time, getting old huh.
The workshop installed two engines that were shipped in, unfortunately both are not running properly. We are now sourcing another one and at the same time opening my original engine to see if a rebuild would make sense. So definitely itching to get back off-road 😣
  • Sad (0) 1
Make sense to check what's inside the old engine and to what extent damage has been done.
Are you in touch with Ahmed from jabal tokyo?
And which all places have you scouted the used engine, I know 3 more places
Yes I forwarded number of Jabal Tokyo to Rishi, the guy that runs the workshop where my car is. He’s been calling around and going to Sharjah on a daily basis to source engines. Please do forward the other places, I might go and check myself in Sharjah on Saturday. I work in Jebel Ali so i can never reach Sharjah during the week.
  1. https://goo.gl/maps/VQsK5hufP2Q2 From Durrah university to Mobil 1
  2. https://goo.gl/maps/tR7jKFa51vm  Keep S115 on the back and walk till the end of shops
  3. https://goo.gl/maps/KvyZ13mTvCR2 From here till Gecko signal - both sides
  • Thanks (+1) 2
Thanks buddy. If ever somebody invents a way to X-Ray or analyze an engine sitting on a pallet he’d be a very rich man 😂. Now it’s buying and trying....
Edited by Frederic Nuyttens
Also, you can call these 6 used spare part guys from your office and see if it helps.
From 3 engine swap experience, unless you run around you won't get lucky, mechanics and workshop always have a few hundred customers other than you so they can't spend enough time for one job.
https://carnity.com/search?&q=mitsubishi&type=cms_records5&nodes=86&search_and_or=or&sortby=relevancy
There is a way to this and I think I posted here too. I'll dig and get you
  • Thanks (+1) 2
