window is stuck half way down
Check the windo fuse first and then switch, if its not electrical failure then it will be mechanical issue of stuck windows sideways.
Open the door cover from inisde and see if glass is misaligned and stuck sideways tilted. If yes pull up glass by hand and stick with scotch tape ad remove the auto window assembly and see the small gear tooth if its skipping or broken. That must have cause this problem.
