Recovery Dampers - what do you think?
Javier M
So I have never used the recovery dampers but it seems they do the job (if done properly).
Have you used them before? what are your thoughts?
Keep it safe my fellow off-roaders!
Edited by Javier M
I always carry two small snatch straps and use them occasionally on tricky or stubborn stucks where chances are high for breaking any tow points or ropes. I also carry the big cloth bag, that I fill with sand and hook up with these straps to absorb the shock.
These days use of soft shackles has reduce the risk of damage to greater extent unless the tow points are weak.
In any case, if you feel stuck is very hard, you can fill sand in any plastic bag and tie it securely with both ends of the rope, which practically does the same thing to absorb shock if any tow point or rope fails.
The idea with these snatch strap is to stop the shock and also stop the retraction to not to damage my vehicle, by sticking this snatch strap end to free tow point or bumper so it will stop the broken part hitting my car even.
