Headlight bulb kia cerato
Zor123
You can pick the same OEM brand or Osram or any similar brand but only thing important is to stick to the same power wattage or code number written on the existing bulb.
Going with standard replacement is highly advisable to not to let your light assembly melt and also different color or quality might blind the incoming traffic and get you police fine for that.
I have learned from my mistake when I change a cornering light bulb in Cayenne with more high power and that melted the light socket and short circuit the whole headlight.
Have a look at below article:
https://jalopnik.com/should-you-swap-your-headlight-bulbs-for-leds-1728026383
While i like the look of LED, i am not in favor of replacing the halogen high-beams and low-beams yet.
