Emmanuel
Every off road driver must know: why you get stuck?
Ok who has a video to post ? (It can be your stuck or someone else’s)
Let's see what our offroaders have to say for this stuck......?
You can post any of your stuck or someone else stuck or even youtube stuck to discuss and learn
  • Like 5
  1. I think he had not enough momentum to go to the top of the dune
  2. There was a sand pocket that made him lost even more momentum I remember we could not even make it to the low part of the dune with the momentum we had
  3. I think that he hesitated to give more gas and steer right once the car sank
  • Like 3
  • Totally Agree 1
Good input @Javier M and thanks for sharing the full-length video to get these little cuts for learning
Let's see what others have to say more......!
It looks as if he encountered one or two serious bumps on that ascend, which made him lose the momentum a bit. The sand indeed looks very soft.
Edited by Frederic
  • Like 3
Looks like not many offroaders are interested here in knowing these secrets, as they are happy being stuck.
My observation: Everything that Fred and Javier's mention is true + when you are in lead you are bound to get these stuck as sometimes you step on deceiving looking sand, that looks hard from top but super soft from below. So as soon as you step on it, you will get stuck. Sometimes in such situation, only your early action of steering down/away can help to escape such stuck.
Emmanuel, please add your viewpoint as a driver in case we have missed any.
  • Thanks 1
  • Totally Agree 2
I think you covered everything, well done. As you mentioned it was a very very soft patch (and again the sand was a bit wet underneath). I will just add one detail : as shown by @Javier M there was a fraction of second of hesitation when I saw the small pocket below on the right. It doesn’t appear clearly on the video, but it was a quite nasty one. I could have got stuck in an even worst way if I had felt in it from this angle.
Let’s see tomorrow 😂
  • Like 3
  • Thanks 1
  • Haha 1
lovely thread, too bad not many people are participating! i have a couple of videos i think from earlier that i can share here, even photos of stucks with my own car
hope it will bring the thread back to life
my question will be, how to self recover from such stuck though? low gear and moving the steering in different directions did not work for example. what would be the next move? where to dig ? where to steer. it is a tricky angel and i feel a wrong recovery may flip the vehicle.
Glad to see your observations @MlHazim. This stuck is actually not that bad. In most scenarios you can turn your wheels towards gravity and in 4Lo with applying gentle blips crawl your way out. If unsuccessful then attach the recovery rope and gently pull the car downwards at the front.
CD430788-341A-4080-B59D-503305C273E1.jpeg.30c8d5ebb1ac1ac03b63d64371d9fe80.jpegin above photo you see a recovery from last week where the car was also at a steep angle. We gently pulled the front of the car downwards and the driver steers completely left. With a gentle tug you can let gravity do the rest.
  • Similar Content
    • By Frederic
      While offroading, we cross dunes by using different methods, based on how the dune is formed and what the drive level is. Once you have spent some time in the desert, you will slowly start to pay more attention to the dune formations and how we cross them. Once you reach Intermediate and Advance level, you'll need to start learning how to read these dunes in order to navigate and create your planned routes in the desert.
      As a rule of thumb, the prevailing wind in UAE is blowing from a North-Western direction to South-East direction:
      This is something you should remember and you will notice when you zoom into certain areas with your navigation app (Google Maps, Gaia, MotionX, Mytrails,...) you will notice that the wind from that side has caused the dunes to take on their shape. This is a general rule and will not always apply, as you will see that in certain areas where wind is coming from different directions, you will see for example "star" dunes appearing.
      There are different types of dunes which are separately described below.  As you can see in below picture, a dune is formed when the prevailing wind blows on a mound of sand, where the grain will move into the wind direction and create a ridge. The sand which falls on the other side of the ridge, creates a slipface, and this sand is not compacted by the wind. This is the main reason why we generally drive on the prevailing wind side or the convex side of the dunes on the Newbie level.
       "A dune is a curiously dynamic creature," wrote Farouk El-Baz in National Geographic. “Once formed, a dune can grow. It can change shape and move with the wind. It can even breed new dunes. Some of these offspring may be carried on the back of the mother dune. Others are born and race downwind, outpacing their parents. [Source: Farouk El-Baz, National Geographic, February 1982]
      The shape of dunes is affected by things like the strength, direction and consistency of the winds; the consistency and amount of sand; the hardness of the terrain and the amount of vegetation.
      Below we will describe the most common dunes found in the UAE.
      Different Dunes
      Crescent or Barchan Dune
      This is the most common dune. It forms the shape of a crescent moon when the wind blows from one direction.
      We generally use the words concave and convex to describe both sides of the dune:
      * Concave is a shape that curves inwards.
      * Convex is a shape that curves outwards.
      Crescent-shaped mounds generally are wider than long. On the concave side you will have the slipface. These dunes form under winds that blow from one direction, and they also are known as barchans.
      Parabolic Dune
      A parabolic dune is similar in shape to a barchan, but it is just the opposite. The tips of this dune point into the wind, and its main body migrates with the wind, forming a depression between the tips. Because of this formation, parabolic dunes are also known as blowout dunes. These dunes often occur when vegetation stabilizes sediments and a U-shaped blowout forms between clumps of plants.
      Example of Parabolic dunes near Faya:
      https://goo.gl/maps/ob8xu3y8VJJvF6hk8
      Longitudinal or "Seif" Dunes
      They are also often referred to to as "sand ridges" or "seifs". Their length can range from a few meters to many kilometers and their height from a couple meters high to a couple hundred meters high. Wind pushes the sand and forms ridges parallel to the prevailing wind direction with slip faces either side of the crest. Linear dunes are straight or slightly sinuous sand ridges typically much longer than they are wide. They may be more than 160 kilometers long. Linear dunes may occur as isolated ridges, but they generally form sets of parallel ridges separated by miles of sand, gravel, or rocky interdune corridors. Some linear dunes merge to form Y-shaped compound dunes. Many form in bidirectional wind regimes. The long axes of these dunes extend in the resultant direction of sand movement.
      Example in Al Qudra area:
      https://goo.gl/maps/RXHFzR3GW6iFr16C7
      Barchanoid Dunes
      These ridges are similar to Barchan dunes. They are connected in long crescentic waves as the sand supply is much greater than that which forms a Barchan Dune.
      Star Dunes
      These dunes are formed when there are several prevailing wind directions - there is a complex wind regime. Typically there are three or more slip faces, whilst the dunes do not migrate they grow in height.
      Star dunes are radially-symmetrical, spyramidal sand mounds with slipfaces on three or more arms that radiate from the high center of the mound. They are created when the winds blow equally from every direction, causing the sand dune to grow many extensions and resemble a star. They are rare and are fairly stable and remain in the same place. Some are landmarks with names.
      Example of a Star dune:
      https://goo.gl/maps/jRnYghQc8ACzVz6T7
      With this knowledge, the next time you step into the desert, you can start looking at the different dune formations, and this will give you lots of knowledge that you'll be able to apply in the future when leading and navigating off-road drives.
    • By Srikumar
      This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through below information and and strictly follow these guidelines in order not to jeopardize someone's health, and to ensure we can keep organizing these drives safely.
      MUST READ AND TOTALLY AGREE: COVID19 Precautions
      MUST READ AND TOTALLY AGREE: BAN POST
      Two Way Radio Guidelines
      Every Offroader brings his own radio, programmed to the frequencies described in below advice topic. We will not share spare radios or program your radio on the drive. If you need assistance in programming the radio, post a topic on the Carnity website with your questions and we will help you out.  Make sure your radio is fully charged. It will be your only way of communication while driving. Before buying, please carefully read below advice so you are informed properly on which model / cost / shops... No radio = No drive. It is an essential tool and you should make sure you bring it on every drive and learn/practice how to use it.
      MUST WATCH: NEWBIE VIDEO BRIEFING
        Drive Details
      Level:  Newbie, Absolute Newbie and Above (All Levels)
      When:  July 10 2020, Friday.
      Meeting time: 5:00 AM (SHARP - Without any exceptions)
      Meeting Point: 2nd Dec Cafeteria - https://goo.gl/maps/MxnMF2fHeGnKZ4vf7
      Approximate finish time: 09:00 AM
      End Point: Tawi Nazwa Farm - https://goo.gl/maps/LjPWf8DebrAuNSWg9
      LIMITED SPOTS AVAILABLE:
      Limited to 15 cars only. RSVP will close on Thursday - 9 AM. 1 Lead Marshal + 2 Senior Members + 12 Members. If the RSVP is full and you wish to join, please mention your name on the drive thread to add on the waiting list.  Latecomers will be returned back - without ANY EXCEPTIONS. Members without RSVP will be returned back - without ANY EXCEPTIONS. Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others. Repeated no-show members after RSVP will have their account suspended for a month.
      PLEASE RSVP ON THE CALENDAR
    • By Frederic
      Join us in exploring the Al Qudra Desert to see what's beyond the lakes, and learn the art of offroading at the same time ! This area is a very versatile playground for Absolute Newbies on their first offroad adventure.
      If you have already driven in sand before, then you can learn more from experts having decades of off-roading experience in the UAE. This area offers a good mix of playable long set of dunes and broad ridges to test your off-road control.
      Drive is open for all 4x4/4WD/SUV/AWD vehicle having 8-10 inches of ground clearance and front and rear tow hooks.
      You can bring your family, friends and kids, but if you are absolute new to sand offroading we advise you to drive alone first to learn off-roading without any distractions.
      What you'll learn:
      Introduction to off-roading Desert driving basics and etiquette Desert driving tips, techniques, myth and best practices Off-road and safety gear familiarization and recovery procedures Vehicle orientation, risk analysis, deflation and outdoor safety advice
      First time with Carnity Off-road Club:
      Please share your vehicle details - Make, Model, Year. Do you have any prior off-road experience? Confirm your vehicle has front and rear tow hooks / eyelets.
      Why should i join?
      We will teach you how to self-drive off-road safely and learn the best offroad driving and recovery techniques. If you have already driven in sand before then you can learn more from experts having decades of offroading experience in the UAE. This area offers a good mix of playable long set of dunes and broad ridge to test your off-road control.
      Can my vehicle do this ?
      This drive is open for all 4x4/4WD/SUV/AWD vehicle having 8-10 inches of ground clearance and front and rear tow hooks. If in doubt please first announce your questions on the drive thread so we can advise you further. Any stock 4x4/4WD are most welcome, you don't need any modified vehicle.
      Can i bring passengers ?
      Yes of course, but if you are absolute new to offroading it is better to drive alone first to avoid any distractions.
      STRICTLY: For ABSOLUTE NEWBIE who are driving for the first time with Carnity.
      MUST READ AND AGREE - COVID19 PRECAUTIONS
        Drive Details
      Level:  All Levels
      When:  Jul 10, 2020 Friday.
      Meeting Point: Al Qudra - https://goo.gl/maps/ZgS2Gqam9PcsxWR48
      End Point: Qudra Parking - https://goo.gl/maps/eV6UEio13s97pKSp8
      Limited to 15 cars only. RSVP will close on Thursday - 5PM. 1 Lead Marshal + 2 Senior Members + 12 Members. If the RSVP is full and you wish to join, please mention your name on the drive thread to add on the waiting list Latecomers will be returned back - without ANY EXCEPTIONS. Members without RSVP will be returned back - without ANY EXCEPTIONS. Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others.
    • By Frederic
      Drive Details
      Level:  All Levels
      When:  June 26 2020, Friday.
      Meeting time: 7:00 AM (SHARP - Without any exceptions)
      Action Plan: Morning drive till about 10:30 AM
      Meeting Point: Qudra Desert Track Entry - https://goo.gl/maps/9ZPffHWmnhioYKff9
      Approximate finish time: 10:30 AM
      End Point: Al Qudra Last Exit Parking - https://goo.gl/maps/L4UYFcLBtpYzFnxr7
