How do i flush the cooling system?
Follow the below procedure:-
1. Remove the lower and top hose
2. Undo the heater hoses
3. Remove the thermostat and then flush out the radiator completely
4. Block and heater core
5. Install new thermostat replace any defected hoses if any
6. Add the coolant and bleed air from system
7. in the last run the engine with heater open feel for heat in both heater hoses as to ensure no air trapped in heater.
hope this helped
