Headlight Adjustment....
Wondering if any one got any experience?
I found the below post and my headlight backs look the same and i managed to adjust the low beam up (before it stopped about 7m in front of the car) by doing aiming against a wall but i cant seem to change the high beam at all today its abit cross eyes and i have a white beam in the middle but nothing at all so i want to pull them apart but nothing seems to happen??
For me the lower screw on the outer light changed the height but the inner as i then took for side to side does nothing??
https://www2.pajeroclub.com.au/forum/showthread.php?t=56720
14 hours ago, Barry said:
Maybe the adjuster screw just isn’t working?
I have a proper headlight beam setter tool in the shop if you need some help setting it up properly.
That would be great!!!!
and its probably working but the problem is most likely user error :D cause it has the same issue on both sides and on both low and high beams....
Just tell me when and where!
Edited by Per A
