Chirag S. Posted June 24, 2019 Author Report Share Posted June 24, 2019 16 minutes ago, MATHEW FELEX said: @Chirag S. I had installed a TRD light weight roof rack on my FJ2 which did not increase the noise heavily, The noise was always there from the front windshield and the side mirrors on the FJ cruisers when you speed on the highways. So the reason maybe they gave a powerful JBL entertainment system, !! @MATHEW FELEX Nice one!! 1 Link to comment Share on other sites More sharing options...
Srikumar Posted June 24, 2019 Report Share Posted June 24, 2019 @Chirag S. have a look at the below video. You will need do something similar for your roof rack to reduce the noise. The other option which is easier is to get a custom made cover, and just close it. 1 1 Link to comment Share on other sites More sharing options...
MATHEW FELEX Posted June 24, 2019 Report Share Posted June 24, 2019 @Chirag S. - if your using the TRD roof rack, you can fabricate something similar which might reduce wind noise 2 1 Link to comment Share on other sites More sharing options...
Chirag S. Posted June 24, 2019 Author Report Share Posted June 24, 2019 3 minutes ago, MATHEW FELEX said: @Chirag S. - if your using the TRD roof rack, you can fabricate something similar which might reduce wind noise @MATHEW FELEX Thanks and So helpful!! Link to comment Share on other sites More sharing options...
Javier M Posted June 24, 2019 Report Share Posted June 24, 2019 It's better if you can buy a prefabricated part before looking to get it fabricated as it may be cheaper. 1 1 Link to comment Share on other sites More sharing options...
desertdude Posted June 24, 2019 Report Share Posted June 24, 2019 Well I would wait until you install your RTT and then see the nose levels. If you get a spoiler now and get a RTT then you might have more noise and then need further work 1 Link to comment Share on other sites More sharing options...
desertdude Posted June 24, 2019 Report Share Posted June 24, 2019 Your choice but then don't complain when someone says I told you so. 1 Link to comment Share on other sites More sharing options...
Chirag S. Posted June 25, 2019 Author Report Share Posted June 25, 2019 13 hours ago, desertdude said: Your choice but then don't complain when someone says I told you so. You're right!! Link to comment Share on other sites More sharing options...
MATHEW FELEX Posted June 25, 2019 Report Share Posted June 25, 2019 21 hours ago, Javier M said: It's better if you can buy a prefabricated part before looking to get it fabricated as it may be cheaper. Hi Javier, I believe what you mentioned as prefabricated part would be the stock FJ air dam that's available as an additional accessory for the TRD roof rack, Not sure if those are available here in the UAE market as I have seen them only on the US spec FJ's but several roof racks are available in different weights and designs for the FJ's locally. @Chirag S. guess an online purchase would do if its cheaper than the fabrication but for sure it would be a perfect fit than the fabricated ones - Good Luck ! 1 Link to comment Share on other sites More sharing options...
Chirag S. Posted June 25, 2019 Author Report Share Posted June 25, 2019 17 minutes ago, MATHEW FELEX said: Hi Javier, I believe what you mentioned as prefabricated part would be the stock FJ air dam that's available as an additional accessory for the TRD roof rack, Not sure if those are available here in the UAE market as I have seen them only on the US spec FJ's but several roof racks are available in different weights and designs for the FJ's locally. @Chirag S. guess an online purchase would do if its cheaper than the fabrication but for sure it would be a perfect fit than the fabricated ones - Good Luck ! @MATHEW FELEX Big thanks for your concern. I will do it!! 1 Link to comment Share on other sites More sharing options...
