SIDDIQUI AHMED
Luxgen U7 Vibration issue
Smells like the axel inners shot.... repaired in a sense that it was checked and repaired or just plop a can of grease and put the boot back..
Edited by shadow79
More info
9 hours ago, SIDDIQUI AHMED said:
If I drop the gasoline pedal at 60, absolutely no vibration is felt in 60-40 band.
Then in this scenario it can't be wheel balancing, its more mechanically powered or engine related issue, that requires physical inspection to be 100% sure.
Totally agree with @Barry and @shadow79 advise and those both are the quiet close possibility as it's vibrating only while hitting the gas.
It's worth digging into how axle has been repaired earlier, because while axle is powered it may be causing this vibration.
  • Totally Agree 1
Im going to make this thread even more confusing and say possible bad ignition coil or worn out joint on the drive shaft if it has one.
  • Haha 1
  • Well Done 1
Bad ignition coil(s) will set misfire codes, but I do agree with you about the cause involving bad driveshaft(s).
Yes exactly Mr. Adel cars & Bikes Al Quoz 3 guy did the same. They told me they took it for some lathe machine and put a new rubber cover with grease.
  • Well Done 1
The Authorized Dealer of Luxgen in DIP suggested to replace the entire Axle "Shaft Assembly Drive" as per the Picture. Can any member advise where to procure Luxgen Parts in U.A.E. or online.
  • Confused 1
Luxgen parts! I swear and Im not kidding here the first time I even heard the name luxgen was in this thread.
Wouldnt the dealer in DIP have parts for it?
  • Haha 2
It's a China car you won't find it in the used unless it's a knock off of any known brand
they do copy German us or Japanese Korean cars but it's a long shot or might as well be a wild chase
He will arrange it and it takes 3-4 weeks
Sorry to say this but if any car dealership take 3-4 weeks for getting parts, that means they themselves is not convince with that brand and just outsourcing parts from Oman, KSA or China just for the heck of it instead of stocking it here.
Used car ownership is a marriage between the parts and service provided by dealer or outside workshop. If you can't find these, then you should be better changing this "UNSUPPORTED" brand with much loved brands in UAE, whose spare part type no:1, 2, 3 and scrap is readily available in a day's time.
  • Totally Agree 1
  • Well Done 1
