UAE'S MOST ENGAGING CAR SITE
I tried to improve my Pajero AC every summer however after I have changed too many parts in my Pajero AC I still have low cooling AC compares to my other cars however after trying a lot I managed to reach at least double the cooling I had here some important tips:
1- Check your AC gas level, it might be low or lacking. it's very common and very very important
2- Change your AC fan, it might be working but not full performance/power.
3- Add an extra fan on the AC condenser (could be fixed along with the main AC fan or with a separate switch or directly connected to the power) recommended to be fixed along with the main AC fan.
4- OR add 2 extra fans one fan for the AC condenser and another fan for the transmission cooler (could be fixed with a separate switch or directly connected to the car power) recommended with separate switch.
    This is mainly good for the transmission cooling, especially while off-roading. However it also helpful for the AC cooling.
5- Disconnect/disable the heater from the car AC system. (it was done to my Pajero by Habtoor). I never used the heater in UAE you might disable it.
6- If you have a LWB you might switch on both AC front and Rear at the same time as they have 2 different evaporators and in the summer it helps a lot if you use them together.
7- Car tinting, if you don't have window tinting do not expect you AC to perform in the summer. Recommended if you use heat Insulation/reduction tinting.
8- Keep your car AC recirculation switch/button ON all the time or at least until you reach the required temperature. I usually keep it on all the time.
9- Keep your car in shaded/covered parking.
***Even if you have done all the above points and your AC gas is leaking or low you will not get any good results.***
Some people might consider the above point are obvious but believe me for some people they are not I thought to share my experience even if it might help one person that would be enough.
**DISCLAIMER** I accept no liability for any harm or damage caused by anyone modifying their car. Always read the workshop manual for your car and consult a qualified mechanic before starting any work.
  • Like 3
Disabling/bypassing the heater matrix is bad and any professional mechanic who recommends it should be stripped of his qualifications. The heater matrix is part of the cooling system and is required for proper operation as per manufacturer specifications. This is a fix done by lazy and incompetent mechanics who have no idea how to replace a heater matrix or think it’s a magic cure for engine overheating, which it isn’t
If you can explain how disabling the heater matrix improves AC cooling then I am all ears although I bet you have never researched this and are going on the advice of someone else who has also not properly researched how automotive HVAC systems work.
  • Like 3
  • Well Done 1
Doesn’t your windows fog up more now ?
  • Like 3
I also want to know more how disabling heater helps in cooling?
On the contrary, heater is a blessing while offroading as occasionally when engine temp start rising and doesn't come to previous level, switch on heat and open all windows and within 30 secs engine temperature drops instead of waiting for 10 mins in idle with hood open. Reason behind this is heater uses engine heat to throw out from the blower and help dissipate lot of heat in seconds.
In UAE I have only used heater once in last 17 years of driving, but every year used heater in summer at least more than 5-10 times while offroading.
  • Like 5
I think weve already had this conversation about heaters here. Mostly disconnected when heater core is clogged or keaking. Not worth the money to rip out the dash to fix it in these climates for something you might need once a year for 5 mins.
But if its workig fine then no need to bypass it. And rightly pointed out it has nothing to do with AC cooling and a quick cooler for an overheating car.
I remeber I had to use the heater on full trickvon my friends overheating maxima while coming back from Al Ain. It worked long enough fir us to reach our shop in sharjah.
But was no fun to drive in mid summer in the heat with the heater on full blast. It was a race against time to see which would faint first the car or us!!!!
  • Like 3
  • Haha 1
I have an easy solution to that, keep driver grills facing you and passenger grills facing other side pointed towards window.
Whenever I need quick engine cool down while driving even, roll down all windows, AC Off, heater on, close my side vent and open passenger vent. Max 30 sec temp drops to normal even while pushing the car in full heat. I
This way have never exceed temp above 110 while 90 is ideal, so I keep waiting till it reaches 110 occasionally to do this trick otherwise it keeps dancing between 100 and 105 range while offroading.
  • Like 4
As i mentioned this was done by habtoor however i did not ask for this as a service they have disabled the heater without asking me. I was told about it when i was reviewing what was done in the car.
However the service advisor confirmed to me that is a common thing they do for Mitsubishi cars to improve the AC. I have not researched this nor thought about the idea behind i should have but when it comes to the habtoor service i kind of trust them more to do the right thing.
If it was a regular car garage i wouldn't have mentioned it or most probably i would have requested them to return it back as it was.
Somehow air conditioning got better in my car.
I will do a deep research on this point, thanks for highlighting this point, this is why we are all here. To learn from each other experiences.
No they're not, i guess it is happening in any car if you direct the AC grills toward the windows. @Frederic
  • Like 3
If this was something done by the main dealer I would be sending an email direct to Mitsubishi in Japan asking for an explanation. Chances are you will get the problem rectified for free. And trust me, when they disconnected your heater matrix, it had no correlation to your AC cooling. I’m sure Mitsubishi would be very interested to hear about this and know the dealer is doing incompetent work by unqualified employees.
Sometimes the doors insulation becomes bad or leaks air which goes through the heater core as well will drop cooling while the AC is on so instead of opening up the havc box and sorting it out we too disabled many heaters as opening up dash vs looping off the heater there is a good cost difference so obviously you know what will be chosen customer...
  • Similar Content
    • By Emmars Auto Repair Shop
      Emmars Auto Repair managed and owned by all Filipino kabayan  is here to provide high quality, convenient and comprehensive auto repair at low cost. The most important aspect of our business is trust. It is the goal of our firm to have 100% customer satisfaction.
      Our Services A/C Air Conditioning, Brake Repair & Service, Cooling Systems, Diagnostics, Electrical Repairs, Exhaust / Muffler Service & Repair, Oil Change / Lube Service, Power Doors & Windows, Radiator Service & Repair, Scheduled Maintenance, Steering, Suspension Service & Repair, Tune-ups, Auto Glass Replacement, Custom Paint, Dent & Scratch Removal, Free Estimates & Appraisals, Panel Repair, Full Body Paint, Wheel Paint, Accident Repairs, Caliper Paint.
    • By Faisal khan
      We provide special pricing for all Carnity members.
      We provide all kind of service for all light vechicles mechanical ,electrical and a.c. fixing.
      We provide 10000 km engine oil change ,flued top-ups , computer & manual health check for 4 cylinder cars 150 Aed. (Oil filter extra)
      We provide 10000 km engine oil change , flued top-ups , computer & manual health check for 6 cylinder cars 250 Aed. (Oil filter extra)
      We provide high quality service with reasonable prices as we have excellent expertise in Motrox.
    • By Handy sharafeldin
      We providing all kind of service for all light vehicles mechanical, electric, bodyworks, painting and oil change with reasonable price and high-quality service.
    • By Roney thomas
      We undertake all major and minor repair of all types of light vehicles specialized in European, Chinese, and Japanese. We have trained technicians for Chinese and Indian buses and we are doing internal shampooing for all vehicles.
      We provide on-site breakdown services and recovery service.
    • By Khaledma2000
      My regards to all,
      I have 2009 FX50 since two weeks i start facing problems with overheating.
      All issues starts when i replaced AC compressor which after replacement AC returns cooling perfect. but suddenly air recyclation was always switched off alone and bad smell comes inside the cabin. I went back to mechanic and he canceled the water heater line which goes inside cabin through front dashboard. Eventhough AC bad smell was gone because of this modification but i noticed the heating gauge was little bit raised up and keep satable . Two days later the car get overheating and i went again to mechanic he found the second fan not working and i replaced it . Now there is no risky overheating, but car not like one month earlier, its simply becomes crazy and still mechanic tell me everything is fine but am sure its not. Now the temperature gauge is raising little bit up if i stop on signal or stuck in traffic, by raising up the rpm raised to 900 instead of 700 , i hear upnormal noises similar to grinding noises , i feel this rough noise when i put my hand on gear stick and the overall temperature in engine compartment is higher than what i used to feel earlier, as a confirmation to this the wheather temperature display on dashboard increases 4-5 c° while stopping car  for 1 min. Meanwhile when i run with car at speed 100km/h for 1 min everything returns fine , no noise , temperature gauge returned to original position, temperature display in dashboard decreases to normal wheather temperature . Can anyone help me on this? If i returned the water heater connection is it going to resolve or affect my problems?
