UAE'S MOST ENGAGING CAR SITE
16 minutes ago, Barry said:
How often do you see battery terminals with post grease on them though? I’ve never even seen it on dealer serviced cars. Servicing in UAE generally means an oil and filter change, if you’re lucky they might blow out the air filter with an air line.
I have a few spare cans of battery post grease if anyone needs some.
Isn’t this just regular white lithium grease ?
  • Totally Agree 1
20 minutes ago, Gaurav said:
I def need one, save one for me please and ill arrange to pick it up. Thnx
Sure. I’ll be at the shop on Saturday. I have a lot of spare cool stuff so I’ll make you a nice little care package full of stuff you didn’t even know existed 😬
  • WOW 2
It’s specially formulated grease with conductive particles to maximise electricity transmission.
In theory, you can use any grease, EP2 works, you can even cover the battery posts in Vaseline if you want. The main aim is to keep the air away from the connection to prevent oxidisation.
  • Totally Agree 1
Not any grease Bhai I once had a car come in with funky starting issue cleaned the grease on the terminal which seemed like he got for free so why not just dip the battery in it....
  • Haha 3
On 8/13/2019 at 7:28 PM, shadow79 said:
Could be still your starter is funky it happens when at multiple attempts it just starts but then gain out of the blue it will not start...it's a good time to take it to workshop
Thanks for the help, I will keep a check on that if next time car fails to start again.
On 8/13/2019 at 7:36 PM, desertdude said:
And cleaning the battery terminal didn't occur to you during all your under hood inspection and trouble shooting, since you describe it as all gunked up.
No, it actually dindt as green powder was hiding inside the battery terminal and when they open it all the mess came out.
On 8/14/2019 at 9:48 AM, Javier M said:
Would recommend to put some dielectric grease on the battery terminals to prevent this issue from happening.
Sure will do, any recommended shop or place from where I can pickup and DIY?
On 8/15/2019 at 2:29 AM, shadow79 said:
If it's well serviced then you won't face terminal funkyness in the first place...
I thought this too and will point out to the service guys next time I visit them.
  • Thanks 1
  • Similar Content
    • By Barry
      How to jump start your car when car battery dies?
      A car with a flat battery can be a real pain. Maybe you left the interior light on overnight, you go to start the car to go to work in the morning but nothing happens. You haven't got time to wait to call a mechanic or breakdown service, you need to be at that important meeting. This is where it comes in handy to always have a set of jump leads in the boot. Especially in a place like Dubai where most cars are automatic and it's not possible to simply push start them. If you haven't already got a set and are going to purchase some, make sure you buy good quality ones made from heavy welding cable. Some of the cheaper, light leads can overheat, melt, short and start a fire which will only add to your misery. If you spend the money on a decent quality item, it should last you for the rest of your days.
      Park both cars close to each other so the jump leads will reach both batteries without being stretched but do not let the cars touch.
      Ensure both vehicles are in neutral with the handbrake on or in park if automatic. Also ensure both vehicles are switched off with the keys out of the ignition.
      Check the terminals on both batteries for corrosion or damage. If there is a problem it will need to be addressed.
      Attach one end of the red lead to the positive terminal on the battery of the dead car then attach the other end to the positive terminal on the battery of the good car.
      Attach one end of the black lead to the negative terminal of the battery on the good car and attach the other end to an unpainted metal part under the bonnet of the dead car such as a large bolt or engine bracket.
      You're almost ready to jump start the dead car. First check that the ends of the cables are all secure and that they will not get caught in any moving parts such as fan, alternator belt etc.
      Start the engine of the car with the good battery and let it run for a few minutes whilst keeping a light rev on then try to start the car with the bad battery. If it starts, all is well and good. If it doesn't, let the car with the bad battery run for another few minutes and try again. If it still doesn't work, check your connections and if it still doesn't work, you may need to change the battery or call a mechanic.
      With both engines running, disconnect the leads in reverse order from which you connected them.
      If the battery in the car which was previously dead is ok, the alternator will charge it up again fairly quickly but if you're still having starting problems, you will need to address them.
      **Disclaimer** I accept no responsibility for any harm or damage caused by anyone jump starting their own car. This is merely a simple guide on how to do it.
    • By victoria
      This is now happened for second time yesterday in one month, that car failed to start. When we jump start car get started. In two weeks back issue car interior lights was getting on but not starting. In yesterday incident car interior light and door ting ping also not working, completely dead.
      When I jump start the car and drive for an hour and leave, car works perfectly fine and start also fine next day. Is the car battery getting old or something is draining the battery out in long stop for over 3-4 days. In both instances this was common that I started the car after 3-4 and 5-7 days gap. Please help.
