Timing Belt and Water Pump
@Frederic has done some similar work on his second Pajero. Let's see what he has to say if he is happy with his garage in Dubai....?
I also need Good garage in Dubai soon, maybe next month end.
Edited by Derick
1 hour ago, Srikumar said:
Actually it depends on what parts are being replaced. The labor cost is typically around 1000 for a workshop in Ajman. If you need to replace any other part the cost can go up or down
I really don't knw wat all will be changed
Usually replacements of belts, bearings, spark plugs, seals, all oils etc. are termed as major services of the vehicle and are mostly done together to save on labor cost.
I’m a regular and happy customer of
Specialised Auto Care In Al quoz that is very reasonable in price.
i brought my wife’s 2008 Pajero for a full service for 200,000 kms that included spark plugs, all oils, water pump, drive belt, etc..
You can enquire with Rishikesh who runs the place with his brother but he might be still in India as he was getting married:
+971 50 115 3454
Near Al Quoz Mall, Ind. Area No. 3، 22nd Street - Dubai
04 341 3799
https://goo.gl/maps/MjJaTVr9DYcdo4769
  • 1 month later...
30 minutes ago, MisterPoet said:
Hi @Sidshk, what is included in the quote of AED 3500/- (parts & labor)?
At times, there are some other items which could you would prefer to change while almost half of your engine is opened; instead of a re-open later with the same expensive labor.
Its was parts inclusive of Water Pump and other stuffs and labor
  • Confused (0) 1
Means it's not only the water pump and timing belt; then it should be fine.
I had the same work done for my Pajero 2012 at start of this year and it costed me almost similar that included Labor along with parts like spark plugs, timing belt, tensioner bearing, crank front seal, water pump, thermostat valve, fan belt, outer belt tensioner, outer belt idler bearing etc.
Hope it helps!
Hope it helps!
Yes all above parts
