Chevrolet General Discussion Forum | Chevrolet Astro Forum | Chevrolet Avalanche Forum | Chevrolet Aveo Forum | Chevrolet Camaro Forum | Chevrolet Caprice Forum | Chevrolet Captiva Forum | Chevrolet Corvette Forum | Chevrolet Cruze Forum | Chevrolet Epica Forum | Chevrolet Express Forum | Chevrolet Impala Forum | Chevrolet Lumina Forum | Chevrolet Malibu Forum | Chevrolet Optra Forum | Chevrolet Silverado Forum | Chevrolet Sonic Forum | Chevrolet Spark Forum | Chevrolet Suburban Forum | Chevrolet Tahoe Forum | Chevrolet Trailblazer Forum | Chevrolet Traverse Forum | Chevrolet Trax Forum | Chevrolet Uplander Forum
Gaurav
How to trace failed TPMS?
In my 2009 Trail blazer, one of the TPMS has gone bad showing the low pressure light on dash all the time. The only way I can think of removing each tire and open it to check all 4 wheels for the faulty one. Is there any other intelligent way to pick a tire that has faulty TPMS and just replace that one than checking all 4 tires.
Oh btw, dash has single icon for low pressure and not for all 4 tires icon, its 2009, lolol.
47 minutes ago, desertdude said:
Doesn't it tell you which tyre is low?
NO
Really, I will write so much if I knew which tire......cmmon.
Shifting has taken a big toll on your sleep.
@Gaurav is there any display in trailerblazer where it shows  low tyre pressure in words along with sign.. If yes then I have a way to find out exactly which tyre sensor is faulty.
If it doesn’t tell you on the dashboard you’ll need a TPMS tool. Point it at the wheels and you’ll see if one isn’t sending a signal. They’re not expensive but a good tyre shop will have one. Some diagnostic computers work through the obd port but it depends on the car.
  • Thanks 1
  • Totally Agree 1
In Ford Explorer 2010 model I had done this DIY to find out which TPMS is faulty. If there is a faulty TPMS it displays "Tire Pressure Sensor Fault" along with sign as shown in the picture below.
To know exactly which tyre sensor is not working just deflate and inflate the tyres one by one...
For Example:
Front left tyre, deflate to 20psi and check the dashboard and if it displays low tyre pressure it means it is working properly. Inflate front left tyre to normal psi and try other tyres one by one. The one with faulty TPMS will not display low tyre pressure and it will remain as shown in the image below as Tire Pressure Sensor Fault. @Gauravbhai if you have this type of display try this.
This is the only icon displays in dash.
