Dune Crossing Tutorial and Techniques
Frederic
On 12/14/2019 at 7:51 PM, Asif Hussain said:
Criss Crossing
Don't try this without experience it requires lot of practice.
Nearly shat myself just watching this video!! We had quite a few intermediate (I think!) ridge-riding and criss-crossing last weekend with @Ale Vallecchi and @Srikumar . While I managed them all (one at the 2nd attempt), I must confess I did not feel confident with any of them. My instinct was to de-accelerate once I crossed and then steer down quite aggressively - so definitively not as per the illustration of @Frederic above.  I was actually contemplating afterwards how I could improve my technique - as "learning on the fly" (the Carnity way?) seems to push the safety margins a bit. Any chance for a bit more instruction on a future trip - maybe step-by-step show with running commentary?  Or maybe I need to book one of the advertised one-on-one courses with @Gaurav (with a few extra sets of clean underpants and air-freshner)?
  • Like (+1) 6
  • Haha (+1) 3
@Kalahari I think you did very well. You did not show much hesitation at all. Surely, I feel there is always an element of uncertainty when you crest a dune, but it becomes less prominent in your mind as you practice more. The reference of the car in front of you certainly helps a lot, and with time the correct ways to approach, cross and exit a dune crest become more natural. Also, each car requires a certain type of feeling with the driver for her/him to become more secure in completing a criss-cross. So practicing (learning on the fly) is almost unavoidable. The clip you show is very advanced in my opinion, due the height of the dunes, their sharpness/inclination, and the speed (and control) required to sustain such ridge riding and crossing for so long. Of course the courses are thought to provide the opportunity to learn the technique, as you mention. But we can also find the opportunity to post a drive which can be almost entirely dedicated to the subject. That will provide the necessary repetitions that even after taking a tutorial will always be needed to go from theory to practice.
You breach a good subject, which I am sure interest many, so stay tuned for something coming soon.
  • Like (+1) 5
  • 5 weeks later...
On 12/5/2019 at 6:36 PM, Frederic said:
Different ways of crossing sand dunes
Throughout the Carnity Offroad briefings you might have heard the terms "straight up and straight down", "side sloping", or "criss-crossing", and these are basically different techniques that we use in desert for crossing the sand dunes.
Each come with its own risks and by learning and understanding the technicalities behind them i hope we can all learn faster and get more confidence in executing them. I hope below tutorial gives a more clear understanding on the subject and we can use it for future reference.
1) Straight Up - Straight Down
Carnity Offroad Level: Newbie and Fewbies
Description
This technique is one of the very first we learn to apply when learning offroading. The trick is to approach the dune straight up with "JUST" enough momentum to make it through, but not too much to damage bumpers or cause a jump.
One should always take into account the resistance that the sand offers based on different areas, and even more on different seasons.
Most sand dunes have two sides
- The windward side, which is the side where the prevailing wind blows on, and can be recognized by the wavy lines of the sand. This is the side where we ride on because the sand is more compacted and firm to drive on.
- The slip-face side, this the softer backside (smooth side, no lines) of the dune which is generally not recommended to climb on, but this technique can later be learned as you advance through the off-road levels (slip-face attack).
How to tackle
It is advisable to start off at the bottom of the dune with applying a decent amount of power, and start letting go of the gas once you have climbed 75% of the dune. By that point the momentum should carry you further, and as soon as the car front wheel touches the crest, leave the gas completely or apply a bit of gentle braking when needed, to let you slide on other side of the dune safely. In fact the perfect technique is finding that right amount of momentum that you don't even need to apply brakes on the other side. Some gentle blips of throttle can help at the top to push you over the edge, as you learn and master this first step.
If you run out of momentum going upwards to cross the dune, do not worry or panic, this is called a REFUSAL. Gently reverse and slowly come back in a straight line as you have climbed up. Announce on the radio that you have a refusal. Reverse up far enough so you can take a second attempt but this time with a bit more momentum.
Risk Level:  Low to medium. Approaching too slow will increase refusal and might cause stuck at the crest. Approaching with excessive speed might damage the bumpers or cause a vehicle to jump. Apply gentle throttle and slowly increase after learning.
Take note that every dune is different and each approach will need to be made slightly different in terms of speed.
Associated RisksIf you approach the dune too fast, more likely you will cause the bumper damage because your reaction time will be reduced substantially at very high speed.
2) Side-Sloping
Carnity Offroad Level: Fewbie and upwards
Description
This technique is very fun and addictive, but it needs to be executed with a clear mind and a good experience on the behavior of the car. That is the main reason why this technique is only used from Fewbie level onwards.  It is very critical to understand how gravity works and as we always says: " DO NOT FIGHT GRAVITY ". this applies to this technique most of all.
When you approach a dune that you want to side-slope on, you need to carry enough momentum to get you through. This does not necessarily mean FULL throttle, because that depends on the type of dune. As soon as your car is on an incline, it will have the natural tendency to try to come down. The more momentum you carry, the further you will get. It is extremely important that you do not fight this by going higher up the dune at that point, but to steer down in a smooth way.  Braking at this point is also very dangerous.
While doing side sloping try to choose smooth path as possible and avoid stepping on rock, bushes or bumps that can bounce you and disturb the whole balance and tip you off or result in dangerous fish-tailing or tire pop-out at high speed.
EVERY MOVEMENT OR ACTION YOU DO WHILE SLIDE-SLOPING NEEDS TO BE DONE IN A SMOOTH WAY, SUDDEN BRAKING OR EXTREME STEERING CAN LEAD TO ROLL-OVERS.
Best practice: Always visually mark the entry and exit of the dune that you wish to do side sloping on. Stick to the initial plan as far as possible and exit safely. If you are new to this, then watch and observe how others have done before and try to replicate that as much as you can.
The best thing to keep in mind is to think about "HALF MOONS" What i mean with that is that you should never make 90° turns during any kinds of these activities, but make smooth half moons during approaching dunes or crossing them.
Risk Level: Medium. With proper training and guidance you can eliminate the risk of a roll-over for 95%, but one should always be aware of the risks involved and take all measures possible to minimize these. Keep both hands at the steering wheel and your full attention on the view ahead. Do not get distracted !
Associated Risks: If your vehicle is lifted more than 4 inch of OEM stock height then your 4x4 center of gravity will be less, and this will increase the risk of roll-over or flip by 50%. Same goes for bouncy (non-standard/rated) suspensions.
3) Criss-Crossing
Description
Criss-crossing is the art of riding the ridge of the dune and crossing over to the other side. Also here it is vital to understand that the approach towards the ridge, as well as the crossing over needs to be done in a smooth, half moon way.
So basically you approach the dune along the length, you can stay on the ridge for as long as you want, but don't lose momentum at this point, or you will be crested lengthwise in the exact middle.
Now the trick is to choose the right point at which you cross towards the other side. This feels scary at the beginning, but soon you will get the hang of it, and cross ridges without panicking at all. Make the criss-cross movement again in a half-moon method as seen below.
Below picture shows the right and wrong way to criss-cross a dune. On the left side you will see that the approach is smooth and as soon as you cross over to the other side you gently steer down. Braking at this point is again very dangerous.
In the right-side scenario, the angle of approach is very sharp, and during higher speeds this can result in a roll-over.
EVERY MOVEMENT OR ACTION YOU DO WHILE CRISS-CROSSING NEEDS TO BE DONE IN A SMOOTH WAY, SUDDEN BRAKING OR EXTREME STEERING CAN LEAD TO ROLL-OVERS.
Associated Risks: If your vehicle is lifted more then 4 inch of OEM stock height, then your 4x4 center of gravity will be less and this will increase the risk of roll-over or flip by 50%. Same goes for bouncy (non-standard/rated) suspensions.
4) Hill Climbing
While this technique is not immediately necessary to cross dunes, climbing a mighty big dune will bring some fun and adrenaline in the equation. At first, you might feel intimidated and not sure if your car can handle this. With the right techniques at hand you can at least make a safe attempt and see how far you can get. This technique can be practiced from Newbie level onwards on small hills, and later you will learn to approach taller dunes from Fewbie level and up.
Again it is extremely important to make a smooth "half-moon" circle at the top. If you run out of momentum and come to a standstill, DO NOT attempt to make a turn, but put your car in 4LO, and slowly reverse down the dune while keeping your wheels straight. The low gearing will help you in keeping that slow pace.
As you begin to learn this, it's always advisable to make a smaller U-Turn to learn how your car reacts and how your mind reacts when you take the first turn on top of dune. This needs to be done with confidence and without any doubt or fear, so that you don't brake on top and do the complete U-Turn without braking and in a very smooth manner. Practicing on small U-Turn will build your confidence and after 5-10 small U-Turn attempt you can try higher and higher by understanding your vehicle dynamics and limitations.
Associated Risks: If your vehicle is lifted more than 4 inch above OEM stock height, then your 4x4 center of gravity will be less and this will increase the risk of roll-over or flip by 50%. Same goes for bouncy (non-standard/rated) suspensions.
Safety of all offroad enthusiasts is the most important thing.  This is an extreme hobby that brings confidence, thrills, and people together as a family. We can only do whatever we can to make all safety instructions clear and concise but in end it's up to the offroader behavior to understand all risk and associated risk involve and enjoy safely.
Open for any questions or comments !
Thanks a lot @Frederic for the excellent write up with illustrations. It helps a lot to understand these basic things for people like me who have no idea of these jargons of dune drives. Feeling more confident now to hit the dune in future with this awareness. That “half moon circle” Logic is really interesting way to keep in mind.
May I also ask about dune bashing and how it’s done safely?
Also we see many performing spinning of their cars in flat surface while taking fast turns and rounds. Are these done in 2WD or some other techniques?
Hi @Biju Abdul. Dune bashing is just a general name for a dynamic driving style in the dunes, in which ridge riding and criss-crossing is a part of. I never liked the description "bashing" as it would mean that we try to destroy the dune, which is the complete opposite of what we should be doing. The real art of offroading exists in "riding" the dunes like a surfer would "ride" the waves. Hence, using the slopes to gain momentum and make it to the next dune by carrying that momentum.
If you drive in a convoy, you need to be aware that there are drivers coming behind you that also want to enjoy the same dune, so churning up the sand and fishtailing all over the place is not the way to do it, as you are completely destroying the tracks.
The spinning while taking fast turns and rounds is called making "donuts". That is being done in 2WD and serves NO purpose other than showing off.
  • Like (+1) 6
  • Totally Agree (+2) 3
Hi @Frederic thank you for your response.
I am in total agreement with you, I too enjoy smooth rides in the desert and enjoy nature and not a fan of stunts, though I am not judging those who enjoy it.
By feeling the comfort level we are getting out of this knowledge (theory), can we think of getting some short briefing by Marshal about what we are planning to do in each drive? As we know that the theory really helps when you learn the same by practicing. I know the covid situation makes it challenging for an open briefing but maybe a line up of convoy in cars with Not Allowed at our line of slight (demo on sand 😎) and the briefing on radio. Just a suggestion because it would really help us to learn faster and safer.
Edited by Biju Abdul
Please read “Not allowed” as “lead” in last paragraph
From Fewbie level onwards, we generally slightly bump up the level and start to bring in the practicing of all these techniques. We have identified in most areas certain "play areas" where you have dunes which are perfect for practicing side-sloping for example and we do take our turns each to practice and guide each-other.
Rest assured that by joining on a weekly basis your progress will be faster than you could have imagined.
See you soon in the sand !
  • Totally Agree (+2) 2
I’m surprised (or maybe I didn’t get what you mean?) because there’s always a briefing, even at fewbie level. If I remember well, at the beginning of the morning drive you attended last Friday, for example, @Wrangeld explained his plan in details and made a radio briefing.
  • Like (+1) 6
Hi @Emmanuel I think I didn’t communicate it well. I was referring to briefing or small demo (on sand) about the general techniques similar to details and illustrations shared in Frederics article.
I have seen some videos of this kind of briefing by some clubs, so thought it would be very helpful for all of us in any levels as we progress in learning.
I have a YouTube video link for a reference but please let me know if I am allowed to share it here. Obviously this video is of time before covid, so it’s an open briefing with people closer than 2 meters distance 😀. Maybe a line up of convoy in cars with Our leader at our line of slight (demo on sand 😎) and the briefing on radio.
  • Like (+1) 6
@Biju Abdul we do brief everyone say for example before going for side slopping and the drive lead is the first one to show and demonstrate how it's done even before any one else is allowed. Before Covid19 we even used to encourage drivers to join the senior members while doing it or the seniors could join the newer member while they performed these manoeuvres to give them confidence. As these are high risk manoeuvres it's not possible to talk on radio while performing them as full attention is required along with both hands on steering wheel.
  • Like (+1) 5
