Oil Leak
If it's from between the transmission and the engine and it's engine oil ( blackish ) then it's the rear main seal. If it's reddish then it's the transmission
All of this is hard to tell from the one solitary dark pic
It's a engine rear main seal, quite prone to fail after certain life. It failed in my Pajero 2 years back too. Fixing it is painful long labor job so make sure you use original Mitsubishi seal, I think it cost 80-100 dhs. Labor might cost you 600-800 dhs (aweer rates), 1000+ (Al quoz rates).
@Barry @desertdude and @treks please advise which option is less labor intensive to remove Engine or Gearbox, and also which one is less expensive in terms lubes and parts required?
  • If engine is removed then will it need new coolant, engine oil, freon etc? or whole assembly can be pulled out?
  • If removing gearbox, does it need new gear oil and filter too?
Removing the gearbox is easier for sure. It’s a days work at most. It’s not necessary to change the fluid but it will need a small top up due to removing the cooler pipes and losing a little bit. Probably less than half a litre.
I wouldn’t even entertain the idea of removing the engine to do it. Too much work involved.
  • Thanks (+1) 2
Pulling out the motor for a seal is a bad idea.
If I were you and remember I'm broke cheap and lazy. I'd just roll with it until it gets real nasty.
OR You can also try some snake oil too. Lucas has a seal leak stopper and people have had some good results with it.
  • Thanks (+1) 2
Thanks @Barry and @desertdude I asked this coz some genius mechanic earlier argued for engine removing in my case, so I thought of bringing some clarity for @Sidshk.
