COVID 19 Compliant - Morning Newbie Desert Drive - Mahafiz - Sharjah - June 5th 2020
This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to respect and follow these guidelines strictly in order to not jeopardize someone's health and to ensure we can keep organizing these drives.
MUST READ: Not following these rules and precautions = Not allowed to drive.
No Gathering | No Briefing | No BBQ | No Eating Together | No Touching | No Hugging
We are only allowed to drive through the desert, as we are driving on the road now. So we will only do the desert driving just by sitting inside our cars at all the times and leave the drive without socializing or coming close to each other.
Just like before we like to continue our desert drives through out the year, but this time we need your immense support to understand the strict control and to help everyone follow them all the time.
How to maintain "STRICT" Social Distancing
  • Meeting point will be set slightly (100m - 200m)  inside the desert track.
  • You individually deflate your tires on the tarmac before reaching the meeting point.
    • While deflating tires, stop cars 10 meters away from any other car.
  • Drive signup on calendar will be closed on Thursday morning by 9 AM.
  • Convoy numbering and briefing will be posted here on this drive post before 6 PM on Thursday.
  • All participants need to read & acknowledge the briefing by clicking "Totally Agree" reaction image.png
  • Switch on your radio when you reach the meeting point on the set frequency advised by the trip lead in the critical briefing here.
  • Once everyone reaches to the meeting point, everyone stay inside the car at all the times.
    • Trip lead will do the roll call, convoy numbering recap, critical briefing over the radio.
    • Any suggestions or issues will be discussed over the radio too.
    • You can also speak to other members through the radio only.
    • So please make sure that your radio battery is fully charged.
  • Once all set, trip lead will start the drive as before.
Refusal and Recoveries with Social Distancing
  • Every drive will have 1 lead Marshal and 1 or 2 supporting senior members/crew.
  • Whenever there is a stuck or refusal, only a Marshal / Senior Member / Crew is allowed to handle the situation.
  • Everyone else including the stuck car driver, stay inside the car - AT ALL TIMES.
  • Marshal / Senior Member / Crew is only allowed to step out to access the situation and do the recoveries:
    • They will wear mask and gloves at all times when they are outside their car.
    • They will try to help self recover through the radio guidance.
    • If not they will use required recovery gear and do the needful (shovel, tug or winch, as required).
    • If at any time Marshal require help, then only you are allowed to step out by wearing face mask and gloves at all times.
Drive completion and inflation
  • There will not be any gathering or sitting down together for food-break like before.
  • Once drive is finished, after reaching the tarmac, everyone is requested to move away 50-100 meters before starting their inflation.
  • For drivers having no compressor, can head to the near by fuel station.
  • If drive is ending at a place where there is no fuel station near by, then trip lead will inform in advance so that drivers having their own compressor can join only.
  • Strictly no sharing of compressors, radio, shovel or any recovery gear, at any times.
Mandatory things you require to attend the drive
  • Face mask - at least TWO face mask is needed in case one get damage or fly away.
  • Disposable rubber gloves - at least two sets are needed.
  • Wear face mask and gloves at all the times, when you are out of your car.
  • Carry plenty of hand sanitizer and object sanitizer (spray).
    • Use your sanitizers generously, whenever you step out to help or recover.
    • Sanitize your hands before getting back into your car.
    • Sanitize your recovery gears, if you have used them.
  • Fully charged and programmed radio - without any excuse - No radio = No drive.
  • Shovel - Must for every car, to do little self recovery
  • Safety flag - Must for every car, like before
  • Compressor - If joining the drives that is ending far from the fuel station.
Mandatory precaution that you need to take at all times
  • Do not step out of your car UNLESS/OTHERWISE advised by Marshal / Senior Member / Crew.
  • No shaking hands, hugs or touching each other.
  • No sharing of food, drinks or recovery tools.
  • If you are not feeling well, please stay at home and take a lot of rest.
  • If you have travel in last 14 days, then please do not attend this drive.
  • If you feel unwell during the drive, please let trip lead know so he can plan an early exit.
  • Not more than 3 pax in a car and if all 3 aren't living together, then they should wear the mask inside the car too.
Two Way Radio Guidelines
  • Every Offroader brings his own radio, programmed to the frequencies described in below advice topic.
  • We will not share spare radios or program your radio on the drive. If you need assistance in programming the radio, post a topic on the Carnity website with your questions and we will help you out.
  • No radio = No drive. It is an essential tool and you should make sure you bring it on every drive and learn/practice how to use it.
MUST WATCH: OUR NEWBIE VIDEO BRIEFING:
Drive Details
Level:  All Levels
When: 05 June 2020, Friday.
Meeting time: 7:00 AM (SHARP - Without any exceptions)
Action Plan: Morning drive till about 10:30 AM
Meeting Point: Mahafiz -  https://goo.gl/maps/n9Hfccra6uQaaGqh9
Approximate finish time: 10:30 AM
End Point: ADNOC Station - https://goo.gl/maps/hGg82AoRqUjn73WA8
LIMITED SPOTS AVAILABLE:
  • Limited to 12 cars only. RSVP will close on Thursday - 9 AM.
    • 1 Lead Marshal + 2 or 1 Senior Members + 9 or 10 Members.
    • If the RSVP is full and you wish to join, please mention your name on the drive thread to add on the waiting list
PLEASE RSVP ON THE CALENDAR
  • Totally Agree (+2) 5
  • Replies 22
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
To me, one of the signs we might be getting back to some sense of normality is that Carnity drives are back. You know that with @Frederic in the lead it will always be well organized and planned so th
RSVP is now Closed. Please find your convoy number below.  Radio frequency will be: Carnity Channel 1: 446.00625 Mhz. Please make sure your radio is charged and set to this
Posted Images
2 minutes ago, Jun Zamora said:
HI Frederic.
Please ignore my request. There is still a spot for evening drive for al qudra.
Thanks
Better be fast then.
Hi @Pickey Singh
As @Brette mentioned last weekend you can get a suction cup to put on your glass roof of the car so you can install an off-road flag. As you surely understand this is a mandatory requirement in the club so we can avoid incidents.
  • Totally Agree (+2) 3
43 minutes ago, Nikola Bozovic said:
Hey guys, I just joined the group, I am friend of yout teammate Jose Martin.
I would like to join the morning drive on 5th jun but site didnt allow mefor some reason.
Can you help about it?
Thanks
Hi @Nikola Bozovic welcome to Carnity Off-road Club !
Currently the drive is already full, as we have a limit of 10 drivers. Keep an eye out for next weeks drive and RSVP as soon as you can.
Thanks a lot for the reply @Frederic I will keep an eye on the drives and hopefully we will meet soon.
Cheers
Subscribe and then join Offroad Club
And enjoy multiple level off-road drives - every weekend.
