Gaurav
COVID 19 Compliant - Evening Newbie Desert Drive -Al Qudra - Dubai - 5 June 2020
Welcome to the COVID 19 "new normal" lifestyle with restrictions and precautions for everyone safety.
Moving forward and respecting authorities guidance all desert drives will be done under strict control.
MUST READ: Not following these rules and precautions = Not allowed to drive.
No Gathering | No Briefing | No BBQ | No Eating Together | No Touching | No Hugging
We are only allowed to drive through the desert, as we are driving on the road now. So we will only do the desert driving just by sitting inside our cars at all the times and leave the drive without socializing or coming close to each other.
Just like before we like to continue our desert drives through out the year, but this time we need your immense support to understand the strict control and to help everyone follow them all the time.
How to maintain "STRICT" Social Distancing
  • Meeting point will be set slightly (100m - 200m)  inside the desert track.
  • You individually deflate your tires on the tarmac before reaching the meeting point.
    • While deflating tires, stop cars 10 meters away from any other car.
  • Drive signup on calendar will be closed on Thursday morning by 9 AM.
  • Convoy numbering and briefing will be posted here on this drive post before 6 PM on Thursday.
  • All participants need to read & acknowledge the briefing by clicking "Totally Agree" reaction image.png
  • Switch on your radio when you reach the meeting point on the set frequency advised by the trip lead in the critical briefing here.
  • Once everyone reaches to the meeting point, everyone stay inside the car at all the times.
    • Trip lead will do the roll call, convoy numbering recap, critical briefing over the radio.
    • Any suggestions or issues will be discussed over the radio too.
    • You can also speak to other members through the radio only.
    • So please make sure that your radio battery is fully charged.
  • Once all set, trip lead will start the drive as before.
Refusal and Recoveries with Social Distancing
  • Every drive will have 1 lead Marshal and 1 or 2 supporting senior members/crew.
  • Whenever there is a stuck or refusal, only a Marshal / Senior Member / Crew is allowed to handle the situation.
  • Everyone else including the stuck car driver, stay inside the car - AT ALL TIMES.
  • Marshal / Senior Member / Crew is only allowed to step out to access the situation and do the recoveries:
    • They will wear mask and gloves at all times when they are outside their car.
    • They will try to help self recover through the radio guidance.
    • If not they will use required recovery gear and do the needful (shovel, tug or winch, as required).
    • If at any time Marshal require help, then only you are allowed to step out by wearing face mask and gloves at all times.
Drive completion and inflation
  • There will not be any gathering or sitting down together for food-break like before.
  • Once drive is finished, after reaching the tarmac, everyone is requested to move away 50-100 meters before starting their inflation.
  • For drivers having no compressor, can head to the near by fuel station.
  • If drive is ending at a place where there is no fuel station near by, then trip lead will inform in advance so that drivers having their own compressor can join only.
  • Strictly no sharing of compressors, radio, shovel or any recovery gear, at any times.
Mandatory things you require to attend the drive
  • Face mask - at least TWO face mask is needed in case one get damage or fly away.
  • Disposable rubber gloves - at least two sets are needed.
  • Wear face mask and gloves at all the times, when you are out of your car.
  • Carry plenty of hand sanitizer and object sanitizer (spray).
    • Use your sanitizers generously, whenever you step out to help or recover.
    • Sanitize your hands before getting back into your car.
    • Sanitize your recovery gears, if you have used them.
  • Fully charged and programmed radio - without any excuse - No radio = No drive.
  • Shovel - Must for every car, to do little self recovery
  • Safety flag - Must for every car, like before
  • Compressor - If joining the drives that is ending far from the fuel station.
Mandatory precaution that you need to take at all times
  • Do not step out of your car UNLESS/OTHERWISE advised by Marshal / Senior Member / Crew.
  • No shaking hands, hugs or touching each other.
  • No sharing of food, drinks or recovery tools.
  • If you are not feeling well, please stay at home and take a lot of rest.
  • If you have travel in last 14 days, then please do not attend this drive.
  • If you feel unwell during the drive, please let trip lead know so he can plan an early exit.
  • Not more than 3 pax in a car and if all 3 aren't living together, then they should wear the mask inside the car too.
Two Way Radio Guidelines
  • Every Offroader brings his own radio, programmed to the frequencies described in below advice topic.
  • We will not share spare radios or program your radio on the drive. If you need assistance in programming the radio, post a topic on the Carnity website with your questions and we will help you out.
  • No radio = No drive. It is an essential tool and you should make sure you bring it on every drive and learn/practice how to use it.
MUST WATCH: OUR NEWBIE VIDEO BRIEFING:
Drive Details
Level:  All Levels
When: 05 June 2020, Friday.
Meeting time: 4:00 PM (SHARP - Without any exceptions)
Meeting Point: Qudra Area -  https://maps.app.goo.gl/Rnv8kvp2WhQGU46D6
Approximate finish time:  8:00 PM
End Point: Qudra Last Exit https://goo.gl/maps/uAS3yNeypFW1V1xy6
LIMITED SPOTS AVAILABLE:
  • Limited to 12 cars only. RSVP will close on Thursday - 9 AM.
    • 1 Lead Marshal + 2 or 1 Senior Members + 9 or 10 Members.
    • If the RSVP is full and you wish to join, please mention your name on the drive thread to add on the waiting list
PLEASE RSVP ON THE CALENDAR
  • Totally Agree 7
Great to be able to try a new place.
Awesome
Edited by E.C. TAN
  • Like 3
Please add me to the next possible waiting list, if sweihan drive get canceled due to the travel restriction to Abu Dhabi  for a week time.
21 hours ago, Nikhil Saju Paul said:
Hi please let me know if anyone is leaving a slot open , would love to join
cheers
Your name has been added to list @Nikhil Saju Paul
19 minutes ago, amro elshafey said:
Please add me to this drive
where can I buy a radio please?
Welcome to the club @amro elshafey
Looks like the drive is already full. Keep an eye on next week's drive and in the meantime you can get things like radio, flag, compressor sorted.
You will find a two-way radio only in Dragon Mart. We recommend buying the:
- Crony/Motorola MT777: Very good radio for about 120-150AED.
- Baofeng UV5-R: Good radio for 75AED.
You will find more info in below advice.
And here you can find instructions on how to program them:
Let us know if you do have more questions.
On 5/31/2020 at 11:28 PM, bunty_and_pops said:
Add me to queue - if any cancellation - thnx
Your name has been added to list @bunty_and_pops
Hi @amro elshafey, welcome to Carnity Offroad Club.
You are now number two in the waitlist, hope to see you soon.
  • Totally Agree 1
