Hi @Rahimdad bhai i will not be able to attend this drive got some other commitment on friday morning. Please give my place to next in line. Thanks.
  • Like 3
My sincere thanks to @George Francis, @Denizzalbayrak, @Gregory Perkin, @Brette and @Anish S for clicking on Totally Agree on my original post on this drive thread.
Can I please request @Vanessa8580, @Yousef Alimadadi, @VipinShetty, @MUHAMMAD Kashif RAZZAQ, @Mehmet Volga, @Magellan and @Jeepie to please click on the Totally Agree smiley on my first post on this drive thread to show agreement to all the information given there.
  • Like 3
Must be my mistake @Vanessa8580. Sorry, I just saw your reaction.
@Rahimdad, if the RSVP limit is not reached and spots are available I would like to join for morning drive. Please let me know when you make the final list . TIA
Thanks you all for totally agreeing with the original post. Only @VipinShetty has not yet clicked on the "Totally Agreed" smiley on my original drive post. If I do not see it before this drive is closed @VipinShetty will be removed from this drive. Dr. @Chaitanya D as a special case I have added your name to the drive, kindly click on the "Totally Agree: smiley on the original post. I will share tomorrow's convoy numbering and Radio Channel we are going to start with shortly.
  • Thanks 1
@VipinShetty you're safe.
  • Thanks 1
  • Similar Content
    • By Frederic
      While offroading, we cross dunes by using different methods, based on how the dune is formed and what the drive level is. Once you have spent some time in the desert, you will slowly start to pay more attention to the dune formations and how we cross them. Once you reach Intermediate and Advance level, you'll need to start learning how to read these dunes in order to navigate and create your planned routes in the desert.
      As a rule of thumb, the prevailing wind in UAE is blowing from a North-Western direction to South-East direction:
      This is something you should remember and you will notice when you zoom into certain areas with your navigation app (Google Maps, Gaia, MotionX, Mytrails,...) you will notice that the wind from that side has caused the dunes to take on their shape. This is a general rule and will not always apply, as you will see that in certain areas where wind is coming from different directions, you will see for example "star" dunes appearing.
      There are different types of dunes which are separately described below.  As you can see in below picture, a dune is formed when the prevailing wind blows on a mound of sand, where the grain will move into the wind direction and create a ridge. The sand which falls on the other side of the ridge, creates a slipface, and this sand is not compacted by the wind. This is the main reason why we generally drive on the prevailing wind side or the convex side of the dunes on the Newbie level.
       "A dune is a curiously dynamic creature," wrote Farouk El-Baz in National Geographic. “Once formed, a dune can grow. It can change shape and move with the wind. It can even breed new dunes. Some of these offspring may be carried on the back of the mother dune. Others are born and race downwind, outpacing their parents. [Source: Farouk El-Baz, National Geographic, February 1982]
      The shape of dunes is affected by things like the strength, direction and consistency of the winds; the consistency and amount of sand; the hardness of the terrain and the amount of vegetation.
      Below we will describe the most common dunes found in the UAE.
      Different Dunes
      Crescent or Barchan Dune
      This is the most common dune. It forms the shape of a crescent moon when the wind blows from one direction.
      We generally use the words concave and convex to describe both sides of the dune:
      * Concave is a shape that curves inwards.
      * Convex is a shape that curves outwards.
      Crescent-shaped mounds generally are wider than long. On the concave side you will have the slipface. These dunes form under winds that blow from one direction, and they also are known as barchans.
      Parabolic Dune
      A parabolic dune is similar in shape to a barchan, but it is just the opposite. The tips of this dune point into the wind, and its main body migrates with the wind, forming a depression between the tips. Because of this formation, parabolic dunes are also known as blowout dunes. These dunes often occur when vegetation stabilizes sediments and a U-shaped blowout forms between clumps of plants.
      Example of Parabolic dunes near Faya:
      https://goo.gl/maps/ob8xu3y8VJJvF6hk8
      Longitudinal or "Seif" Dunes
      They are also often referred to to as "sand ridges" or "seifs". Their length can range from a few meters to many kilometers and their height from a couple meters high to a couple hundred meters high. Wind pushes the sand and forms ridges parallel to the prevailing wind direction with slip faces either side of the crest. Linear dunes are straight or slightly sinuous sand ridges typically much longer than they are wide. They may be more than 160 kilometers long. Linear dunes may occur as isolated ridges, but they generally form sets of parallel ridges separated by miles of sand, gravel, or rocky interdune corridors. Some linear dunes merge to form Y-shaped compound dunes. Many form in bidirectional wind regimes. The long axes of these dunes extend in the resultant direction of sand movement.
      Example in Al Qudra area:
      https://goo.gl/maps/RXHFzR3GW6iFr16C7
      Barchanoid Dunes
      These ridges are similar to Barchan dunes. They are connected in long crescentic waves as the sand supply is much greater than that which forms a Barchan Dune.
      Star Dunes
      These dunes are formed when there are several prevailing wind directions - there is a complex wind regime. Typically there are three or more slip faces, whilst the dunes do not migrate they grow in height.
      Star dunes are radially-symmetrical, spyramidal sand mounds with slipfaces on three or more arms that radiate from the high center of the mound. They are created when the winds blow equally from every direction, causing the sand dune to grow many extensions and resemble a star. They are rare and are fairly stable and remain in the same place. Some are landmarks with names.
      Example of a Star dune:
      https://goo.gl/maps/jRnYghQc8ACzVz6T7
      With this knowledge, the next time you step into the desert, you can start looking at the different dune formations, and this will give you lots of knowledge that you'll be able to apply in the future when leading and navigating off-road drives.
    • By Srikumar
      This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through below information and and strictly follow these guidelines in order not to jeopardize someone's health, and to ensure we can keep organizing these drives safely.
      MUST READ AND TOTALLY AGREE: COVID19 Precautions
      MUST READ AND TOTALLY AGREE: BAN POST
      Two Way Radio Guidelines
      Every Offroader brings his own radio, programmed to the frequencies described in below advice topic. We will not share spare radios or program your radio on the drive. If you need assistance in programming the radio, post a topic on the Carnity website with your questions and we will help you out.  Make sure your radio is fully charged. It will be your only way of communication while driving. Before buying, please carefully read below advice so you are informed properly on which model / cost / shops... No radio = No drive. It is an essential tool and you should make sure you bring it on every drive and learn/practice how to use it.
      MUST WATCH: NEWBIE VIDEO BRIEFING
        Drive Details
      Level:  Newbie, Absolute Newbie and Above (All Levels)
      When:  July 10 2020, Friday.
      Meeting time: 5:00 AM (SHARP - Without any exceptions)
      Meeting Point: 2nd Dec Cafeteria - https://goo.gl/maps/MxnMF2fHeGnKZ4vf7
      Approximate finish time: 09:00 AM
      End Point: Tawi Nazwa Farm - https://goo.gl/maps/LjPWf8DebrAuNSWg9
      LIMITED SPOTS AVAILABLE:
      Limited to 15 cars only. RSVP will close on Thursday - 9 AM. 1 Lead Marshal + 2 Senior Members + 12 Members. If the RSVP is full and you wish to join, please mention your name on the drive thread to add on the waiting list.  Latecomers will be returned back - without ANY EXCEPTIONS. Members without RSVP will be returned back - without ANY EXCEPTIONS. Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others. Repeated no-show members after RSVP will have their account suspended for a month.
      PLEASE RSVP ON THE CALENDAR
