Frederic Posted August 9, 2020 Report Share Posted August 9, 2020 8 hours ago, sertac said: I bought the multi-meter and yesterday i decide to check the compressor. I wanted to give it one more try. I connect it and few times i on and off the switch, it start working but this time it was running forever even if i switch it off it is still running. This made me think that switch is the faulty. I check around it but i couldn't find easy way to remove and change the switch. Have you guys know any shop can change it properly? https://www.amazon.ae/MiMoo-Rocker-Switch-Household-Appliances/dp/B07B2S5QYN/ref=mp_s_a_1_5?dchild=1&keywords=10+amp+micro+switch&qid=1596985838&sr=8-5 You can easily replace yourself. 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
