3 minutes ago, Ahab Shamaa said:
Hey @Foxtrot Oscar, @Niki Patel, @Chaitanya D, @sertac, @Emmanuel, @Mohamed Seidam, @topgear, @Srikumar, @Jefy, @GauravSoni, &@Gaurav. I’ve almost tried it all 😂 I hate, absolutely hate rattling and things moving around while off-roading. I’ve tried to tie down bags, nets, external bags on my spare tire, bags on my roof rack(not practical), and nothing has quite worked like the molle panels. They are great and can hold just about anything; provided you use good quality, to purpose tie-downs.  Having said that, if you do decide to get some molle panels, go for good quality ones that will support the weight of equipment; including a 2 ton hydraulic jack 😀. Some panels in the market, are cheaply made and will bend and crackle when driving or under load. Some companies produce specific panels for your particular car, and I found those to be the best, since fit is perfect and they have installation instructions and support. In any event, even with a bit of a higher spend, it’s a once in a lifetime investment and worth every penny 😀
One last thing; there are literally hundreds of bags and holders that are  designed for the molle panels, which is a great thing. This system is still being used by militaries around the world to this day.
Here are some pics from the back of my FJC; everything is nice and tidy 😀
I feel I need to turn on VPN to view this!  Why am I so excited by these pics? 😳 ....
I love being organized and this is a dream setup!!! Thanks for sharing Ahab and the genuine review of the Molle panels
  • Replies 81
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Just wanted to share with all the xterra owners here .Easy way to secure cargo with bungee cords and spring nuts. These can be found at Golden Screws Ras Al Khor.  Pictures are self explanatory
As Gaurav said above,   I have a big military bag with everything in the bag (multiple compartments, yes also the jack). I always secured it with bungie ropes (or how do you call these thing
Posted Images
You have well thought clean setup @Ahab Shamaa. Thank you for the pics.
BTW if below pic is 2 ton jack, where is it mounted in your trunk. i cant quite figure it out from this picture.
Also how did you secure below big box in your trunk floor.
Edited by Rizwanm2
Thanks @Chaitanya D! I knew the doctor in you would appreciate a bit of tidiness 😀
@Rizwanm2, the box is something I built out of plywood, and secured it in an outer shell that I had bought from Amazon. I secure the whole thing to the FJ’s floor via ratchet straps, who in turn are attached to the trunk’s floor (the  FJC has 4 attachment points in the floor of the trunk). That thing doesn’t budge despite the jumps and bumps were subject our cars to 😀
As to the Pro Eagle Jack, it’s mounted to my rear door. I have temporarily removed it, to reinforce the mounting points where the molle panel attaches to my rear door. The steel on the Toyota is much weaker than the steel used on the molle panel. So in order to ensure the attachment points on the FJ do not bend/warp, the garage is fabricating reinforcement brackets that will bolt on to the FJ’s door under the plastic cover panel. I’ll show it to you next time we meet 😎
@Ahab Shamaa excellent job buddy indeed , thanks for sharing the visuals 👍
only one thing crossed my mind isn’t it better to secure the 2t floor jack horizontally , from fluid ( oil ) stasis in gravity dependent position that theoretically may leak by time ) !
Edited by Mohamed Seidam
There’s a reason why you’re a doctor @Mohamed Seidam 😀 Helping people is in your blood, and you can’t help reading and understanding user manuals no matter how long and boring they are 🤣
Thanks for sharing this information buddy! I’m reconsidering my setup after reading this. Now I will either store the jack horizontally as the manufacturer suggested, or I will wrap it with a Spinneys bag to collect the oil that leaks out 😂
  • Haha (+1) 4
Hey @Hisham Masaad, yes indeed, you have a beautiful FJ as I recall, and I owe you some pictures from our scenic drive wih @Ale Vallecchi in RAK 😀
Since we’re not allowed to post names here, I would say do a search for FJC Molle panels. A few results should come up. I got mine shipped from the US and installed here. Good luck with this and let me know if you don’t have any luck finding what you need... We’ll figure out something else 😀
  • Similar Content
    • By Zed
      Alhamdulillah I survived a rollover that happened yesterday. I've been watching the dashcam recording and trying to remember what I did wrong, but my brain seems to block the memory of the moments before it happened, so I'm reaching out to the experts here, what could be the cause of my rollover? *dashcam video attached below
      Some stuff that I can think of:
      a. Did I lose momentum? The bottom speed timestamp says I went from 48km/h, 46, 44, 37km/h before rolling over.
      b. Did I get a tyre pop-out? When I got out of the car, both of my left tyres popped out. I had to use a jack and fill them up to 40psi to make the tyres pop-in back again and to drive the car outside the desert. But maybe the left  tyres popped out due to the rollover to the left? If that so, why are my right tyres intact (right tyres didn't pop out). I was driving with 15psi all tyres btw.
      c. At the 00:02 footage, you can see the Jeep in front of me swerved to the left. What the camera didn't show was that the Jeep went on drifting on my left side instead of exiting gracefully with the nose down first. Basically in a quick moment I turned my face to the left, seeing a car on my left side and scared that if I also exit-left-with-nose-first to go with gravity, I might crash into the Jeep... could I have done something wrong with my reflex? Like maybe letting go of the gas pedal to slow down cause afraid of crashing with the car on the left side. Someone said "look front when driving off-road and don't be distracted by left and right sightseeings." I should have focus straight and not be afraid of my left side.
      d. I was the last of the convoy, so nobody was behind me, otherwise maybe that person could tell from behind what went wrong...
      PatrolRoll.mp4
    • By Atif
      I have always wondered why Adaptive Cruise Control (ACC)  is not a compulsory requirement in all cars. None of my cars ( Pardo 2014 and Camry 2006)  has it, although I am aware the more expensive cars do have them ( Mercs.)  Most people will state that it is the cost that prevents it but I would like to know if it is more expensive than the air-bags installed in most cars ? I can only assume that the front sensing system may be expensive .
      While sitting next to new drivers ( like my son and daughter) the first thing that I have to watch out for is the judgement of the braking distance. A large percentage of accidents on our roads are due to this misjudgment . With high speed urban driving even an experienced driver may have faced emergency braking scenarios ( I have).
      I believe that electronic sensors like most electronic components are getting cheaper so why the delay in this option. Even if it may have some negatives consequences , it should be available in all cars even if it is has optional activation switch.
      Perhaps those who have ACC or know the cost can comment about the hurdle that stops the manufacturers from installing this life saving device.
    • By Atif
      I am a regular user of cruise control while driving, both for ease and felt it seemed more fuel efficient.I engage it at any opportunity where the speed is over 60 KM/HR and traffic is flowing.
      I do however keep coming across failed cruise control instances on the roads. In fact, I  came across the following advice in Gulf News after the last incident locally:
      https://gulfnews.com/uae/what-to-do-if-your-cars-cruise-control-fails-1.2275388
      I wonder what is your view about this. Do many people use cruise control?
    • By vivian
      A very interesting video demonstrating why we need to maintain a speed limit of 30kmph in Residential areas. Must watch.
      VID-20180125-WA0001.mp4
