Thanks @Gaurav for the details. It is nice to see our journey with clear objectives and plans. I think it is this systematic approach and discipline shown by Carnity is making all of us so attached to the club. Most of us reaching the meeting point atleast half an hour before the drive is the testimonial of this passion. ☺️
  • Totally Agree (+2) 3
@GauravThanks a lot for the detailed information with clear structural levels. Feels myself like a newborn baby learning the first steps to walk. Lot to go....each drive day gives me a bunch of experience and knowledge to take home...Thanks to carnity for giving us the oppurtunity to learn and grow..
  • Gaurav featured and pinned this topic
Based on growing experience under different terrains and conditions, we are proud to announce our off-road grading structure with much needed further enhancements.
New changes are highlighted in red color above, to further enhance the safety and learning growth of every offroader.
  • Like (+1) 6
  • Totally Agree (+2) 2
  • 1 month later...
Hi @Gaurav just to understand for Advance promotion you have mentioned that feedback from 4 marshals is required for supporting on Newbie or Abs Newbie drives. Is this to be requested by drivers directly with Marshals or will it be checked by Carnity team? Also should we apply for these drives under Manage tag or the usual way, as generally Manage tab is only for Advance and above?
A bit more info on the same would be helpful.
Also can the drives be Fewbie as well or just newbie or abs newbie?
  • 2 weeks later...
Hi @varunmehndiratta I will try to give some replies:
  1. Feedback is from a minimum of 4 different marshals when you are supporting, as agreed with the lead that you attend as a support driver. The marshals will give feedback internally first. The need for 4 different marshals is to remove any possibility of bias in the assessment.
  2. You can ask a lead for specific feedback after a drive, as this will always be the same feedback they should be giving to the team.
  3. Support roles are to be agreed in advance with the drive lead.
  4. If you are accepted as a support, the drive lead will add you to the drive as manage.
Support roles are always at the discretion and decision of a drive lead. This means that no-one can sign up for a drive and expect that they will be or are entitled to be used as support.
As to the level of drives this is newbie level, but this should not be thought of as a numbers game i.e. I did my 4 support drives, now I can be promoted. This is about demonstrating a commitment to the values of teamwork of the Carnity leaders as much as competence in the activity. You are of course welcome to offer support for Fewbie drives. There is nothing stopping anyone at the pre-advance stage offering support in any drive.
Subscribe and then join Offroad Club
And enjoy multiple level off-road drives - every weekend.
  • Similar Content
    • By Zed
      This video is dedicated to the 7 Camaraderie of Bu Tais @Farouq Owdeh @Taufique Surve @Hasan Wahlan @Karthikeyan Govindarajan @xavier @Mus_hus78. Remember what HeadMaster @Asif Hussain says: Follow the track 😂😂😂
    • By Zed
      Thanks to @Hasan Wahlan, I found the trick to getting LandCruiser to climb up with power & ease is to shift it manually to L (in 4-High of course). Unfortunately I was too excited with this discovery and fear of getting stuck on the crest triangle made me step on the pedal a bit too much 😂
      So my LandCruiser flew, as soon as it touched down @Srikumar bhai asked me to check the radiator. Radiator was ok and we continued... Two days later "clicking" noise started coming from the front-driver side, as seen from this video:
      Can you guess what the culprit is?
      If you say CV Boot close enough, it did start with the CV Boot leak, but eventually I had to replace the whole front-left axle 😂  No need to buy new one though, new OEM will cost 2000dhs++ , since i may break it again *touch wood, a good second-hand that costs 400dhs is enough for now 😄
    • By Gaurav
      Driving off-road is very interesting and entertaining experience but there are few basic things you need to check first before heading for your first off-road drive with Carnity Off-road Club.
      Every driver should know when to join for an offroad drive and when to pass until all below things are checked.
      VEHICLE
      Ground clearance: Minimum 8-12 inches under front and rear bumper is must. If your vehicle has 8 inches then you should be careful while driving and slow down while descent and approach to avoid any minor bumper damage. If your 4x4 have EAS (electronic suspension), lift it to the max height and then measure it. Also read the manual to know what is the max speed you can drive with off-road height, as many manufacturer limit up to 60 Kmph with off-road height, which is plenty in most cases. Knowing that limit is better in case you go above that speed, so you can lift it again once you slow down.
        Tow hook: Your 4x4 should have at least 1 tow hook in the front and 1 tow hook at the back, more the better. Also you should check the integrity of all tow hooks and its appearance, if they are shaking or rusted or missing a bolt, then get them fix before joining any off-road drive.
        Engine: Your 4x4 engine should be in perfect working condition without any check engine light or any warning lights on dashboard or leaking oil or coolant. Engine takes more stress while offroading so well serviced 4x4 performs better on off-road. If you recently bought the car and have no idea of last service, then its highly advisable to get the engine service before your first off-road drive.
        Gear / Transmission: Your 4x4 should have LO and High gearing option. AWD or SUV without LO/HI gearing option, generally not advisable for sand off-roading. If you have extensive offroading experience to tackle such vehicles then discuss it on the forum with the trip leader and see if they can allow such exception.
        Suspension: Your 4x4 vehicle suspension should be in reasonable and drivable condition. You can drive with stock suspension perfectly fine and then you can decide to modify it, if really needed. Any suspension lifted up to 5-6 inches are accepted, anything above 5-6 inches lift need trip leader approval before joining any drive to make sure if you have widened the wheelbase to lower the center of gravity in an orderly manner.
        Tires: Your 4x4 tires should be in good condition with enough tread and more than half life left. Tires nearing their end usually fail while offroading, so check for date of manufacturing shouldn't be more than 3 years. No visible cuts or lost tread chunks or cracking sidewall should be there.
        Fuel Tank: You should always join the off-road drive with full fuel tank, as all vehicle consume double or triple the amount of fuel while off-roading. You don't need to change the fuel type from special to super for off-road purpose, continue with your fuel type as per manufacturers recommendation.
        Sign up: Once you have checked all these above points then RSVP the drive calendar and post an introductory message on the drive post - sharing your 4x4 details, previous off-road experience (if any), so that trip lead can acknowledge and plan the drive accordingly.
      OFF-ROAD GEAR
      You don't need any off-road gear or recovery gears for your first off-road drive, but if you have a shovel, flag and a radio (walkie talkie) then please carry it with you. Rest all the off-road gears and recovery tools will be shown to you once you attend the briefing and you can read more about them here: https://carnity.com/advice/offroad/most-comprehensive-list-of-off-road-gears-and-recovery-tools-r81
      OFF-ROAD DRIVE
      Always wear long sleeve and closed shoes (no sleepers) to avoid any injury or sun burn. Carry hat/cap/scarf, in case you need to spend long time under the sun. Carry plenty of water and soft drinks of our choice to keep you hydrated. Carry your camera mounts if you like to record the drive (no hand held). No carrying or consumption of any type of alcoholic drinks on the drive.
    • By Frederic
      While offroading, we cross dunes by using different methods, based on how the dune is formed and what the drive level is. Once you have spent some time in the desert, you will slowly start to pay more attention to the dune formations and how we cross them. Once you reach Intermediate and Advance level, you'll need to start learning how to read these dunes in order to navigate and create your planned routes in the desert.
      As a rule of thumb, the prevailing wind in UAE is blowing from a North-Western direction to South-East direction from 10AM onwards. At night and in early morning it will be reversed and blow from the South-East to North-West.
      This is something you should remember and you will notice when you zoom into certain areas with your navigation app (Google Maps, Gaia, MotionX, Mytrails,...) you will notice that the wind from that side has caused the dunes to take on their shape. This is a general rule and will not always apply, as you will see that in certain areas where wind is coming from different directions, you will see for example "star" dunes appearing.
      There are different types of dunes which are separately described below.  As you can see in below picture, a dune is formed when the prevailing wind blows on a mound of sand, where the grain will move into the wind direction and create a ridge. The sand which falls on the other side of the ridge, creates a slipface, and this sand is not compacted by the wind. This is the main reason why we generally drive on the prevailing wind side or the convex side of the dunes on the Newbie level.
       "A dune is a curiously dynamic creature," wrote Farouk El-Baz in National Geographic. “Once formed, a dune can grow. It can change shape and move with the wind. It can even breed new dunes. Some of these offspring may be carried on the back of the mother dune. Others are born and race downwind, outpacing their parents. [Source: Farouk El-Baz, National Geographic, February 1982]
      The shape of dunes is affected by things like the strength, direction and consistency of the winds; the consistency and amount of sand; the hardness of the terrain and the amount of vegetation.
      Below we will describe the most common dunes found in the UAE.
      Different Dunes
      Crescent or Barchan Dune
      This is the most common dune. It forms the shape of a crescent moon when the wind blows from one direction.
      We generally use the words concave and convex to describe both sides of the dune:
      * Concave is a shape that curves inwards.
      * Convex is a shape that curves outwards.
      Crescent-shaped mounds generally are wider than long. On the concave side you will have the slipface. These dunes form under winds that blow from one direction, and they also are known as barchans.
      Parabolic Dune
      A parabolic dune is similar in shape to a barchan, but it is just the opposite. The tips of this dune point into the wind, and its main body migrates with the wind, forming a depression between the tips. Because of this formation, parabolic dunes are also known as blowout dunes. These dunes often occur when vegetation stabilizes sediments and a U-shaped blowout forms between clumps of plants.
      Example of Parabolic dunes near Faya:
      https://goo.gl/maps/ob8xu3y8VJJvF6hk8
      Longitudinal or "Seif" Dunes
      They are also often referred to to as "sand ridges" or "seifs". Their length can range from a few meters to many kilometers and their height from a couple meters high to a couple hundred meters high. Wind pushes the sand and forms ridges parallel to the prevailing wind direction with slip faces either side of the crest. Linear dunes are straight or slightly sinuous sand ridges typically much longer than they are wide. They may be more than 160 kilometers long. Linear dunes may occur as isolated ridges, but they generally form sets of parallel ridges separated by miles of sand, gravel, or rocky interdune corridors. Some linear dunes merge to form Y-shaped compound dunes. Many form in bidirectional wind regimes. The long axes of these dunes extend in the resultant direction of sand movement.
      Example in Al Qudra area:
      https://goo.gl/maps/RXHFzR3GW6iFr16C7
      Barchanoid Dunes
      These ridges are similar to Barchan dunes. They are connected in long crescentic waves as the sand supply is much greater than that which forms a Barchan Dune.
      Star Dunes
      These dunes are formed when there are several prevailing wind directions - there is a complex wind regime. Typically there are three or more slip faces, whilst the dunes do not migrate they grow in height.
      Star dunes are radially-symmetrical, spyramidal sand mounds with slipfaces on three or more arms that radiate from the high center of the mound. They are created when the winds blow equally from every direction, causing the sand dune to grow many extensions and resemble a star. They are rare and are fairly stable and remain in the same place. Some are landmarks with names.
      Example of a Star dune:
      https://goo.gl/maps/jRnYghQc8ACzVz6T7
      With this knowledge, the next time you step into the desert, you can start looking at the different dune formations, and this will give you lots of knowledge that you'll be able to apply in the future when leading and navigating off-road drives.
    • By Gaurav
      A big Shout-Out to all our offroad club members from across the globe 🌍
      Congratulations on reaching a new milestone of having over 50+ Nationalities Offroaders in Carnity Offroad Club. One of the very few off-road clubs in UAE that welcomes and appreciates multicultural members.
      At Carnity Offroad Club, we drive united as a truly multicultural family, bringing with us our thoughts, experiences and share interesting knowledge with our ever-expanding Carnity family. We pride ourselves at speaking different languages, having different views on our car knowledge and Off roading, but drive in Unity as it is the - way of life in true Dubai, UAE style.
      So come and join our Carnity Offroad Club and add your own special flavour to enhance UAE’s ever-popular Offroad experience.
      Below is the list of the various nationalities. In some nationalities even though there might be more within our group, we have mentioned only max 3 people. If we have missed out any nationality, please let us know and we shall update this list.
      50 and counting - as of July 2021
      Afghanistan: Ali Abbas Ali, Abu Muhammad  Argentina - Martin, Miguel Ibarbia Bangladesh - Jalil Belgium - Frederic, Vanessa8580 Brazil - Jorge Stepniak Felippe, Daniel Noguira, Canada - Adam Marston China - Zixuan Hang (Charlie)  Denmark - Soren, Frederik Bisbjerg Egypt - Melenany, Mark Sorial, Nabil Bishara El Salvador - Mario Cornejo  Finland - Matti Brockman, Tero Vallas France - Emmanuel, Frederic Demolder Germany - Ace1988 Greece - Stav Hungary - Tamas Hoffmann, Archibald Jurdi India - Srikumar, Asif Hussain, Gaurav,  Indonesia - Zed, IMAMP Iraq - Aus Alzubaidi Iran - Yousef Alimadadi Ireland - Barry Italy - Magellan, Ale Valecchi, Lorenzo Candelpergher, Luca Palanca Falsini, Enrico Biscaro Jordan - BIG T, G.Huz Lebanon - Edouard Malaysia - E.C Tan Mauritius - AnishS, Veedooshee,  Mexico - Javier M  Morocco - Jamy B Netherlands - Panda82, Xaf, Jeepie, Mels Wolf,  New Zealand - Warren Flay Pakistan - Rahimdad, Bilal Ahmad, Atif Palestine - Mohamed Seidam The Philippines - Jun Zamora, Rinelle Sanaani, Kaile Barrameda Poland - Szymon Stankiewicz, Piotr Kolodziej Romania - Arman Russia - Mikhail Lukichev Scotland - Foxtrot Oscar Serbia - Marko Todorovic, Predrag Acimovic Singapore - Jerry Han Spain - Vsmano, Nacho, Jose Martin, Sri Lanka - Rizwanm2, Athula and Yasas South Africa - Gawie Herholdt, Colin Jordan, Hennie Schoeman, Jeandre Bezuidenhout, Kalahari  Sweden - Per A, M.K, Christian Andras  Switzerland - dberclaz Syria - Noor, Basil Turkey - Sertac, Halit Mert Issever, Denizzalbayrak, Mehmet Volga Ukraine - YevgeniyDYM United Kingdom - Richard Melish, LewisCocks90, Wrangled United States of America - Jeffrey Osito Pilgreen United Arab Emirates - Shehab Alawadhi Venezuela - Alexander Alcala
