EBS and traction sign
It should be ESP - Electronic Stability Program OR ABS.
Do you have traction control off switch in your model?
@Jun Zamora which year your wrangler is?
23 hours ago, Arun Mathew said:
Hello guys !!!
Kindly help me out with the sign on dashboard for EBS & traction control during dessert drive on my 2010 Jeep Wrangler .
Should I install a switch or any other solution which would help me in the dessert .
Regards
Arun
In my case . It still appears on the dashboard specially when im negotiating a difficult dune. Even if i already turned it off. And it slows my car’s  performance in climbing. Somebody suggested me to install  a Kill Switch. And now i’m ok.
Kill switch is the best option . However one press on traction switch , turns off 50% ... press it for 10 sec , it turns off 70% .
Or otherwise , maybe your suspension is just too soft / weak , that when your tyres are in the air ..the traction indicator keeps showing up
  • 3 weeks later...
Hi Arun , I face the same issue with my car, but haven't felt any loss in power, so did you install a kill switch, if so plz help me with the details
Hi @Arun Mathew ,about the lights  of ABS and traction control lights, I discussed with a friend of mine and in his opinion pulling out the fuse is a better option than installing a kill switch. I did the same and took a small trial and worked perfect for me. After the drive we can reinstall the fuse and the lights disappear in a couple of minutes
