Fuel pump recall
FJ Cruiser is having a fuel pump recall for 2014 FJ.  Al Futtaim Toyota had replaced it for free last week although my car is out of warranty under the recall campaign.
I did some research on the recall and below is what i found. The cars that might be applicable for Middle East from the list below would be Avalon, Corolla, Land Cruiser, Tundra and Camry. Worth checking if you or your friends have these vehicles.
https://www.courtesytoyota.com/toyota-fuel-pump-recall.htm
Toyota Vehicles impacted by this fuel pump recall
  • 2017 & 2018 & 2019 Toyota Sienna
  • 2014 Toyota FJ Cruiser
  • 2018 & 2019 Toyota Avalon
  • 2018 & 2019 Toyota Sequoia
  • 2018 & 2019 Toyota Corolla
  • 2014 & 2015 & 2019 Toyota 4Runner
  • 2014 & 2015 & 2019 Toyota Land Cruiser
  • 2018 & 2019 Toyota Tundra
  • 2018 & 2019 Toyota Tacoma
  • 2018 & 2019 Toyota Highlander
  • 2018 & 2019 Toyota Camry
  • Well Done (+2) 3
All recalls and TSB are always or mostly free, and it has no connection with warranty. Car manufacturers are doing recalls even after 10 -15 years.
Nice info you shared with everyone to help here. Well done.
Agreed that it is the car manufacturers' responsibility even way after the warranty period.
Whilst I appreciate the FOC replacement under the recall campaign, I would appreciate a bit more proactive actions like publicizing or reaching out to car owners via telephone messages to tell them to schedule an appointment for the replacement regardless whether they service with the agency or not. For my case, I discovered it by chance when I showed up for a regular service.
Upon further research, apparently, if the fuel pump is faulty, it may just cut fuel supply and the car will just stall. Will be a tricky situation in the desert, esp in the middle of some sort of maneuver.
That means it was a TSB as they get to wait for car to come back for service.
Recalls done for critical component failure and usually dealer HAVE TO CALL the owner to schedule an earliest appointment.
32 minutes ago, topgear said:
@GauravWhat does TSB stand for?
Technical Service Bulletin
Check more here recalls for Toyota, updated since 2018.
https://carnity.com/recall/toyota
