COVID 19 Compliant - Morning Fewbie Desert Drive - Ghantoot - Little Sweihan - Dubai - 29 Jan 2021
Ale Vallecchi
This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through below information and strictly follow these guidelines in order not to jeopardize someone's health, and to ensure we can keep organizing these drives safely.
MUST READ AND TOTALLY AGREE: COVID19 Precautions
MUST READ AND TOTALLY AGREE: BAN POST
Two Way Radio Guidelines
  • Every Off-roader brings his own radio, programmed to the frequencies described in below advice topic.
  • We will not share spare radios or program your radio on the drive. If you need assistance in programming the radio, post a topic on the Carnity website with your questions and we will help you out.
  • No radio = No drive. It is an essential tool and you should make sure you bring it on every drive and learn/practice how to use it.
Drive Details
Level:  Fewbie and Above
When:  29 January 2021, Friday.
Meeting time: 7:00 AM (SHARP - Without any exceptions)
Action Plan: We will be aiming to drive first to Ganthoot, then on to Little Sweihan (on the other side of the fenced military area) and finally through this magnificent dune set back north toward Solar park, via the "Middle Earth" in between. Technical areas, long range dunes, sand bowls and canyons, sabkhas, sand tracks will be our playground.
Meeting Point: https://maps.app.goo.gl/AtgREn7JpaU6XnaC9
Approximate finish time: Not earlier than 12:00PM
THIS IS A COMPRESSOR ONLY DRIVE. WE WILL STARTING AND ENDING THE DRIVE AT THE SAME POINT, WHICH IS NOT CLOSE TO AN AIR LINE. IF YOU DO NOT HAVE A COMPRESSOR, PLEASE DO NOT SIGN UP FOR THIS DRIVE. IF YOU ARRIVE AND HAVE NO COMPRESSOR YOU WILL NOT BE ALLOWED TO JOIN THE DRIVE.
LIMITED SPOTS AVAILABLE:
  • Limited to 10 Fewbie and above drivers. RSVP will close on Thursday - 9 AM.
PLEASE RSVP ON THE BELOW CALENDAR
Wow was really looking forward to this after i couldn't get the slot in last long drive by Prof Ale.... Can I add myself in list before the One Second window opens .😄 Plz.  Hope those who couldn't get slot last time will get some pref @Ale Vallecchi
Edited by varunmehndiratta
Hi @Ale Vallecchi, probably a stupid question as your drive already mentions "Dubai",  just need to check if will we be required to carry a covid negative test result for this drive (not sure if the start and end point would be within Dubai or Abu Dhabi limits)?
3 minutes ago, Ahab Shamaa said:
Please add me to waiting list @Ale Vallecchi. First drive 😀
Hello @Ahab Shamaa. #1 on the WL. Hope to see you. Thanks.
Hello @N@ved. No need for a test. We'll stay within Dubai. See you.
Hello @Aravind Padmaraju. You are #2 on the WL. Thanks
1 minute ago, Islam Soliman said:
@Ale, joined the AD IM drive so will keep this as my 2nd.. pls add me to your WL
Hello @Islam Soliman. With pleasure. You will be #3 on the WL. Thanks
26 minutes ago, Senthil Kumar said:
Please add me in waiting list, if I get slot in this drive, i will exit from other one (faya drive) at same time,
Hi @Senthil Kumar. I will place you at #4 in the WL. Thanks
