Hi guys
I've recently bought a 2003 Lumina SS. It's in good condition family owned.
Just yday I had to go pick up my friends little brother from AD ( from dubai )
So I just wanted to see what this car was made of so I took it up to 200km ( not for long 3sec max)
And I noticed the traction control was off and it wouldn't turn on I pulled over and the car was shacking
The rmp was not settled it kept dropping.
And not when I turn on the car it tell me check engine.
I don't know what to do and I haven't got the slightest clue on
What's wrong..
Anybody has an idea on what might be wrong ??
Thank you
This is typical issue when car is not been run for long time at hi speed and all of sudden you drive at hi-speed, these issues are pretty common. Nothing really wrong in driving the car until the meter is allowing, its just that you could have revved the car for few times at 140 then 160, then 180 and then 200, instead in it one go. My advise is to take car again at 160+ and after that try again 200 (safely) if it allows and it should come back to normal. If not then better check computer to what code it tells and deal from there. Inshallah everything will be good.
