COVID19 Compliant - Morning Fewbie Desert Drive - Tawi Nazwa to Big Red - Sharjah - 15 May 2021
Jeepie
This drive is organised in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through below information and and strictly follow these guidelines in order not to jeopardise someone's health, and to ensure we can keep organising these drives safely.
MUST READ AND TOTALLY AGREE: COVID19 Precautions
MUST READ AND TOTALLY AGREE: BAN POST
Two Way Radio Guidelines
  • Every Offroader brings his own radio, programmed to the frequencies described in below advice topic.
  • We will not share spare radios or program your radio on the drive. If you need assistance in programming the radio, post a topic on the Carnity website with your questions and we will help you out.
  • No radio = No drive. It is an essential tool and you should make sure you bring it on every drive and learn/practice how to use it.
Drive Details
Level:  Fewbie and above
When: Saturday 15 May 2021
Meeting time: 5:30 AM (SHARP - Without any exceptions)
Meeting Point: https://goo.gl/maps/ez7NkXEttoXk2CqV7
Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance.
Approximate finish time: 9:30 AM
P.S. Only join if you have a compressor to inflate your tires after the drive.
LIMITED SPOTS AVAILABLE:
  • Limited to 20 cars maximum. RSVP will close on Thursday - 9 AM.
    • If the RSVP is full and you wish to join, please mention your name on the drive thread to add on the waiting list
  • Members that do not confirm the terms of the COVID requirements will be removed from the RSVP list.
  • Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others.
  • Repeated no-show members after RSVP will have their account suspended for a month.
Please RSVP on below Calendar
5 minutes ago, Jeepie said:
Waitlist
1 Watteau
2 Thomas Varghese
3 Rawad Bahsas
4 Malachy McGrogan
5 Humayun Ghias
6 Werno
Richard has just offered to lead a second convoy,  so you are all in and I will change the RSVP to 20
Thank you @Jeepie. In case you need help in support I'm here. 🖐️
