COVID19 Compliant - Morning Fewbie Desert Drive - Sand to Mountain: The Sequel - RAK - 21 May 2021
This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through below information and strictly follow these guidelines in order not to jeopardize someone's health, and to ensure we can keep organizing these drives safely.
MUST READ AND TOTALLY AGREE: COVID19 Precautions
MUST READ AND TOTALLY AGREE: BAN POST
Two Way Radio Guidelines
  • Every Off-roader brings his own radio, programmed to the frequencies described in below advice topic.
  • We will not share spare radios or program your radio on the drive. If you need assistance in programming the radio, post a topic on the Carnity website with your questions and we will help you out.
  • No radio = No drive. It is an essential tool and you should make sure you bring it on every drive and learn/practice how to use it.
Drive Details
Level:  Fewbie and above
When:  21 May 2021, Friday
Meeting time: 5:30 AM (SHARP - Without any exceptions)
Action Plan: A drive in a little travelled area for off-roaders, in rather technical, but accessible, terrain. The pace may be slow, and the skills required will include finesse and control, due to the need to pick the right path through an environment with abundant vegetation (shrubs first, then trees), with sporadic animal farms, sets of soft sand dunes with little room to maneuver, and open sabkhas. This drive will test the complete set of off-roading skills, providing a good opportunity to make you a more complete desert driver. Part of the drive will explore an area of longitudinal dunes where we'll practice ridge riding on very soft tops.
Meeting Point: https://goo.gl/maps/UsVoyEaC9YdZdJbG8
Approximate finish time: 10:30 AM
THIS IS A COMPRESSOR ONLY DRIVE. WE WILL END THE DRIVE AT A POINT WHICH IS NOT CLOSE TO AN AIR LINE. IF YOU DO NOT HAVE A COMPRESSOR, PLEASE DO NOT SIGN UP FOR THIS DRIVE. IF YOU ARRIVE AND HAVE NO COMPRESSOR YOU WILL NOT BE ALLOWED TO JOIN THE DRIVE.
LIMITED SPOTS AVAILABLE:
  • Limited to 10 Fewbies and above drivers. RSVP will close on Thursday - 9 AM.
PLEASE RSVP ON THE BELOW CALENDAR
  • Gaurav changed the title to COVID19 Compliant - Morning Fewbie Desert Drive - Sand to Mountain: The Sequel - RAK - 21 May 2021
3 hours ago, varunmehndiratta said:
Fingers are already warming up for rsvp to open...was from scenic perspective the best drive of last 6 months, looking forward..🙂
fingers crossed.  insha allah..  im sure there will be 2 convoys for this drive... 🤐
also im sure our seniors will make it happen.. 😛
25 minutes ago, Chris Wing said:
You guys are way too fast! WL me too please :)
Hi @Chris Wing. Will place you at #2 in the WL. Thanks
17 minutes ago, PaoloMaraziti said:
WL please , I was looking for it.
Ciao @PaoloMaraziti. You are #3 in the WL. Thanks
