COVID19 Compliant - Evening Fewbie Desert Drive - Badayer - Sharjah - 24 May 2021
This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through below information and and strictly follow these guidelines in order not to jeopardize someone's health, and to ensure we can keep organizing these drives safely.
MUST READ AND TOTALLY AGREE: COVID19 Precautions
MUST READ AND TOTALLY AGREE: BAN POST
Two Way Radio Guidelines
  • Every Offroader brings his own radio, programmed to the frequencies described in below advice topic.
  • We will not share spare radios or program your radio on the drive. If you need assistance in programming the radio, post a topic on the Carnity website with your questions and we will help you out.
  • No radio = No drive. It is an essential tool and you should make sure you bring it on every drive and learn/practice how to use it.
MUST WATCH: NEWBIE VIDEO BRIEFING
Drive Details
Level:  Fewbie and above
When: 24 May 2021, Monday
Meeting time: 5.00 PM (SHARP - Without any exceptions)
Meeting Point: Safari Minimart   https://goo.gl/maps/kBcxFygg3d91smr8A
Approximate finish time: 7.30 PM
P.S. Only join if you have a compressor to inflate your tires after the drive.
LIMITED SPOTS AVAILABLE
  • Limited to 10 cars only.
PLEASE RSVP ON THE CALENDAR
  • Gaurav changed the title to COVID19 Compliant - Evening Fewbie Desert Drive - Badayer - Sharjah - 24 May 2021
19 minutes ago, Russ said:
Hi @Tamas Hoffmannis this an AM or PM drive, description says Afternoon but start time says 5am! Cheers
Its an evening weekday drive from 5 PM - 7:30 PM
2 minutes ago, Shaaz Sha said:
Hi @Tamas Hoffmann, my car is under a maintenance and I expect to receive it today, once I receive it I would probably try to get a slot in the drive. 😁🙏
Sure 😊 as you can see people aren't killing each other for tomorrow's drive so iam sure you'll get a place in case you car will be repaired
@Russsorry for the confusion it's an afternoon drive
Good morning Everyone
Today afternoon we will have a small but nice group and thanks to all of you who signed up
Convoy positions will be the following
1 @Tamas Hoffmann
2 @TT_Dubai
3 @Darren Brooke
4 @Thomas Varghese
5 @Russ
6 @Chaitanya D
Radio frequency will be discussed on the spot
Looking forward to see you all in the afternoon 😊
  • Thanks (+1) 2
  • Well Done (+2) 2
Hi @Tamas Hoffmann. I have added myself to manage the drive, as discussed on the WA group. I hope you don't mind, even though I see you also got Chaitanya to support. See you later.
@Ale Vallecchiof course I don't mind
Happy to have your support 😊
