cam shaft sensor
ramsom
The cam sensor is somewhere on the cylinder head and should be easy to replace.
If you look at the lower right of the valve cover the cam sensor is in the side of the head just below the valve cover. It's small black and has two wires going to it.
Hope ur cam timing isnt off, what code u got???
